Rotational Edge Drop: Angular Velocity & Translation
The discussion centers on a physics problem involving a box that is 27.5" tall and 41" long, weighing 480 lbs, which is partially elevated and dropped to assess its rotational behavior. The main focus is on determining whether the box will continue to rotate and fall onto its side after being dropped from a height of 12" while one edge rests on a 3.5" tall block. The user has successfully calculated the angular velocity but struggles with translating the motion when the box switches the edge it rotates about. The inquiry emphasizes the need for understanding the dynamics of rotational motion and edge transitions. The conversation highlights the complexities of analyzing rotational motion in practical scenarios.
toddar
So here is the problem I have. There is a box that is 27.5" tall and 41" tall with a mass of 480lbs. One edge is put on a 3.5" tall block while the other is raised 12" and dropped. The question is to see if the block will continue to rotate and fall on it's side. I have been able to find the angular velocity but am unable to translate that portion of it when it switches edges it is rotating about.
Welcome to the PF.
Where's the egg?
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
