Rotational Kinematics-Vinyl Record
  • Thread starter Thread starter aokidopi
    Rotational
The discussion revolves around a problem related to rotational kinematics, specifically focusing on the spacing of grooves on a vinyl record that spins at a constant rate. The original poster presents a scenario involving a vinyl record's rotation and the distance between its grooves, raising questions about the interpretation of the problem and the calculations involved.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants explore the meaning of the question regarding the distance between grooves, with some questioning the original poster's understanding of what is being calculated. There is a discussion about the expected units for the answer and the implications of the calculations presented.
The conversation is ongoing, with some participants providing clarifications and guidance on the interpretation of the problem. There is an acknowledgment of confusion regarding the calculations, and attempts to clarify the units and the nature of the grooves are being made.
Participants are working under the assumption that the problem requires understanding the physical spacing of grooves in centimeters, and there is a focus on ensuring the calculations align with this interpretation.
aokidopi
1. In the “old days”, long before CD’s and MP3’s, people listened to music using vinyl records. Long-playing vinyl records spin at a constant rate of 33-and-one-third rpm (revolutions per minute). The music is encoded onto a continuous spiral track on the record that starts at a radius of 30 cm from the center and ends at a radius of 10 cm from the center. If a record plays for 24 minutes, how far apart are the grooves in the track on the record?
2. 60 secs=1 min. circumference=2pi(r)
3. The vinyl spins at 33 1/3 revolutions per minute. In 24 minutes, it spins 800 revolutions. A revolution is the 360 degrees of a circle. If the vinyl record travels at a constant rate, the avg. radius it travels at is 20 cm. 20 cm times 2 pi is the avg. circumference. This multiplied by 800 revolutions is approximately 100,000 cm. But this is the incorrect solution
Thanks in advance.
Do you know what you are calculating?
I thought the grooves were the microscopic indentations of the vinyl. It asks for how far apart the grooves of the track on the record are. I thought this implied the length of the continuous groove. If this is wrong, please help me understand the question.
No problem, I will help you:).
What units do you expect your answer to be in?
It is asking in centimeters.
Yes, I'll help you along. It is asking you how far apart the grooves are in centimetres. So maybe centimetres per groove is an ideal unit for you?
Oh...800 revolutions is 20 cm. So 0.25 cm per groove?
*0.025
Thank you dacruick for clearing that up. Doh!
Haha you're welcome :smile:
9K
17K
