Rotational Motion - Centripetal force
To determine the maximum speed a car can cross a hump-backed bridge without losing contact at the highest point, a force analysis is essential. The normal force exerted by the bridge on the car becomes zero when the car is about to leave the ground. The relationship between centripetal acceleration and gravitational force leads to the equation v² = gr, where g is the acceleration due to gravity and r is the radius of the bridge. This means that the greatest speed is directly related to the radius of the arc. Understanding these forces is crucial for solving the problem effectively.
Ch3m_
A hump backed bridge is in the form of a circular arc of radius 35m.
What is the greatest speed with which a car can cross the bridge without leaving the ground at its highest point?
F = m v2/r = mrω2
I've tried using the equation above but no speed, angular velocity or mass is given.
Am I missing something?
You're supposed to find the speed!
Do a force analysis of the car as it tops the bridge. Hint: What force tells you when the car is just about to leave contact with the ground?
The reaction force..? I still don't get it :(
Yes, the normal force that the bridge exerts on the car. What will its value be when the car is barely making contact with the road? What will ΣF be in that case?
It must be greater than the weight of the car = mg? I don't know how to get an exact value though
You are making a false assumption. Start from scratch:
What are the forces acting on the car at the highest point?
If the car is moving at speed v, what is the acceleration of the car?
What equation does that give you?
If the car went a little bit too fast it would leave the ground (you are told). What would the reaction force be then?
Likes Ch3m_
You have the normal force acting upwards, the cars weight acting downwards and the centripetal force acting downwards?
a = v2/r ?
Weight + centripetal force so mg + (mv2)/r ?
No, centripetal force is not an applied force. It is that component of the resultant force which produces the centripetal acceleration.
Ch3m_ said:
a = v2/r ?
Weight - centripetal force so mg - (mv2)/r ?
Yes, that is the normal force whilst in contact with the ground. But if it just on the point of losing contact, what extra does that tell you about the normal force?
Likes Ch3m_
Wait so is it v2=gr?
Yes.
Likes Ch3m_
Thanks, that must mean the normal force = 0 when the car is on the point of losing contact yeah?
Well, it is because the normal force is zero at that point.
