Rotational Motion: Energy Conservation
The discussion focuses on a physics problem involving a sliding block and a pulley system, where energy conservation principles are applied to predict the velocity of the block at a second photogate. The user successfully sets up the energy equations, incorporating kinetic energy and friction, leading to a calculated velocity of 1.5855 m/s. They express uncertainty about whether this result is coincidental or valid. The conversation emphasizes the importance of understanding acceleration and rotational dynamics to derive the correct final velocity. Overall, the energy method proves effective in solving the problem accurately.
SpringWater
the sliding block has a mass of .850kg the counterweight has a mass of .420kg , and the pulley has a mass of .350kg with outer and inner radius .030m, .020m, the coefficient of friction is .250. the pulley turns the axle. the light cord does not stretch and does not slip on the pulley. The block has velocity of .820m/s towards the pulley when passes by photogate . use the energy method to predict the velocity it moved to a second photogate. .700m away?
I understand how to set up the problem using
ΔKE (initial)= ΔKE (final)
however i am wondering if this is possible...
Ke(m1)+KE(m2)+KE(rot)=(uk)(m1)(g)(X)
(V)^(2)*((.5)(m1)+(.5)(m2)+(.5)(I)(1/(r)^(2)))=(μk)(m1)(g)(X)
Where I=2.275E-4 & r=.02m & X=.7m By doing this i get V=1.5855 m/s
This is the correct answer! Did i get the correct answer just by coincidence or is this actually possible?
Use the fact that W=ΔEk
So you get:
h=separation between photogates
a=acceleration of the system
m=mass of the block moving through the photogate
M=mass of the other block
v=velocity of the system
mah=0.5m(v22-v12)
So the only thing you need to know in order to solve for v2 in the equation above is a, which you can get using rotational formulas and Newton's laws.
