Rotational motion of belt drive
The discussion revolves around a mechanics problem involving a belt drive system and the relationship between tension, torque, and acceleration. For a constant velocity scenario, the user initially states that tension T equals torque N, which is incorrect as torque should be expressed in terms of radius. When considering a lubricated bearing and uniform acceleration, the user correctly derives that T equals 0.5Ma. The conversation highlights the importance of understanding the relationship between torque and force, leading to the correction that T should actually equal N/R. This emphasizes the need for clarity in applying physics equations in rotational motion contexts.
kidsmoker
I'm just working through a few past mechanics papers and this question came up:
A belt drives the circumference of a cylindrical wheel of radius R and mass M with
no slipping. The tension in the belt is T. Friction in the wheel bearing causes an
effective torque N to act on the wheel.
(i) If the velocity of the belt is constant, what is T in terms of N.
(ii) The bearing is lubricated removing all significant friction and the velocity of
the belt then increases with a uniform acceleration a. Write down T in terms of
M, R, and a.
I'd be greatful if someone could just check through my solutions so that I'm sure doing things correctly.
I=0.5mR^2 for disc
v=wr
L=I(dw/dt)
(i) T=N .
(ii) v=wR implies dw/dt = a/R .
Therefore TR = 0.5MR^2 * (a/R) ,
and so T = 0.5Ma .
Thanks.
One thing I immediately noticed. In T \neq N Why? because this is saying that Force is equal to torque. Surely you know the relationship between torque and force.
Ah yeah woops! Should be T=N/R ?
Thanks.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
