Calc Angle of Refraction in Opaque Drinking Glass Problem
  • Thread starter Thread starter U154756
To solve the problem of calculating the angle of refraction for an observer looking into a cylindrical opaque drinking glass, Snell's law can be applied, but determining the initial angle is crucial. The observer's position relative to the glass rim and the bottom edge provides necessary geometric relationships. When the glass is empty, the observer sees the bottom edge, while a full glass allows visibility of the center, indicating a change in viewing angles due to refraction. The index of refraction of the liquid, 1.29, is essential for applying Snell's law effectively. Clarifying the angles involved is the key to starting the calculation process.
U154756
A cylindrical opaque drinking glass has a diameter of 4.7 cm and a hieght h. An observer's eye is placed to where they are just barely looking over the rim of the glass. When the glass is empty, the observer can just barely see the edge of the bottom of the glass. When the glass is filled to be brim, the observer can just barely see the center of the bottom of the glass. The liquid in teh glass has an index of refraction of 1.29. Calculate the angle at which the observer is looking into the glass.
I could use Snell's law if I could figure out one of the angles in the equation. I am not sure on how to start this problem. Does anyone have an idea on how to obtain one of the angles from the information given. I know it has to be something simple that I am not thinking of.
Science news on Phys.org
**Bump**
I would like to know if anyone has found a way to solve this.
Please help.
-U
Thread 'Simple math model for a Particle Image Velocimetry system'
Hello togehter, I am new to this forum and hope this post followed all the guidelines here (I tried to summarized my issue as clean as possible, two pictures are attached). I would appreciate every help: I am doing research on a Particle Image Velocimetry (PIV) system. For this I want to set a simple math model for the system. I hope you can help me out. Regarding this I have 2 main Questions. 1. I am trying to find a math model which is describing what is happening in a simple Particle...
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
