Running 3 motors in circuit, where to insert lipo alarm?
To connect a lipo alarm for a modded Nerf blaster, it should be wired in parallel to the power supply to accurately read the voltage. Running three motors may cause voltage fluctuations, but adding a capacitor can help smooth out these spikes and improve the voltage readout. The capacitor should be sized adequately to avoid significant drainage during motor operation and can be placed in parallel with the alarm. Recommendations suggest using a larger capacitor if frequent changes in motor power are anticipated. Properly integrating these components will enhance performance and reliability.
Stoph
Hi all!
I'm working off of this schematic for a modded Nerf blaster (note: schematic not my own work).
I am hoping to hook up a little lipo alarm (http://rcbitz.com.au/images/MiniLipoAlarm.jpg ) somewhere in there to display the voltage of my 1s lipo I'm using to power it.
Question:
Where can I put it that it will read the voltage, and will running 3 motors intermittently cause false readings?
Hope that makes sense!
- C
Just the voltage of the power supply? Connect it in parallel to the power supply. Depending on the motors, the voltage might oscillate a bit, then the displayed voltage will depend on details of the voltage measurement. An additional capacitor could reduce those oscillations.
Thanks! That helps.
So a capacitor would smooth out any spikes to both operation of motors and readout of voltage, yes? Any cap size recommendations? And that would go parallel into the circuit before or after the voltage meter? Thanks!
Right.
Enough to not get drained significantly within one revolution of the motors. Maybe even larger if you want to change the motor power frequently.
There is no before and after. Both parallel to the power supply.
mfb said:
Right.
Champion! Thanks mfb!
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
