petrushkagoogol
- 28
- 4
Could we have a stable gravitational system with 2 Moons :
* In the same orbit
* In different orbits ?
* In the same orbit
mfb said:Well, two Trojans for a moon would be at least three moons already.
Trojans are 60 degree ahead or behind of the main body. There is nothing 180 degrees apart.davenn said:are you saying you cannot have 2 Trojans 180 deg from each other ?
ahhhh OK ... wasn't totally sure of the arrangementmfb said:Trojans are 60 degree ahead or behind of the main body. There is nothing 180 degrees apart.
You can have a moon (#1), and a smaller moon (moon #2) as trojan ahead or behind. If you want a second trojan, you are at moon number 3. Which is perfectly fine, but the question was about two moons.
A satellite is a man-made object that is launched into orbit around the Earth. Its purpose is to collect and transmit data, such as images and measurements, for various purposes including communication, navigation, and scientific research.
Satellites stay in orbit due to a balance between the Earth's gravity pulling it towards the ground and the satellite's forward motion, which creates a centrifugal force that pushes it away from the Earth. This allows the satellite to maintain a stable orbit around the Earth.
Yes, satellites can collide with each other in rare cases. This is why it is important for satellite operators to carefully track and monitor the positions of all satellites in orbit and make adjustments when necessary to avoid collisions.
Satellite orbits can be classified into three main categories: low Earth orbit (LEO), medium Earth orbit (MEO), and geostationary orbit (GEO). LEO satellites orbit at an altitude of around 500-2000 kilometers, MEO satellites orbit at an altitude of around 2000-36,000 kilometers, and GEO satellites orbit at an altitude of around 36,000 kilometers.
The orbit of a satellite can affect its function in several ways. For example, a satellite in LEO will have a shorter orbital period and can provide more frequent coverage, but will have a smaller coverage area. A satellite in GEO will have a longer orbital period and a larger coverage area, but will have a delay in communication due to the distance from Earth. The type of orbit also affects the amount of fuel needed for the satellite to maintain its position, and the level of radiation exposure the satellite will experience.
