Schutz - A First Course in GR - Simple Summation Question
CFDFEAGURU
Hello all,
In the book "A First Course in General Relativity" by Schutz (1985 Edition) in chapter 2 there is a problem concerning summation that has me confused.
Note: This is not homework, just an interest of mine.
The given quantities are:
A = (5,0,-1,-6)
B = (0,-2,4,0)
C = [ 1 0 2 3
5 -2 -2 0
4 5 2 -2
-1 -2 -2 0 ]
Find:
A (super alpha) * C (sub alpha, beta); for all beta.
As usual, I apologize for not using LaTex but I can never get it to work right.
My attempt.
The only sum is on alpha because it is the only repeated upper and lower index. I should end up with a set of 4 numbers.
I followed the example given on page 41 of the book and applied it to this problem, but I got all 4 numbers wrong.
For the first value I calculated:
(1)*(5) + (0)*(0) + (2)*(-1) + (3)*(-6) = -15
The answer is given as (7, 1, 26, 17).
Any help on what I am doing wrong would be greatly appreciated.
Thanks
Matt
Matrix multiplication is defined by (AB)_{ij}=A_{ik}B_{kj} (when we write all indices downstairs), so what you're supposed to calculate is AC, not CA^T.
Thanks Fredrik,
I know that I am supposed to calculate AC, but I keep getting the wrong values. In the example given in the book, Schutz simply multiplies each row of the matrix (C) with the column vector (A) and then sums the values. Very easy and straightforward. What am I doing different that is causing me to calculate the wrong values.
... not CA^T .
What would make you think that I am trying to calculate A transposed times C?
Thanks
Matt
CFDFEAGURU said:
Hello all,
A = (5,0,-1,-6)
B = (0,-2,4,0)
C = [ 1 0 2 3
5 -2 -2 0
4 5 2 -2
-1 -2 -2 0 ]
Find:
My attempt.
Thanks
Matt
You are approaching as follows for \beta=1:
T_{\beta}=C_{\alpha\beta}A^{\alpha},
Or in the matrix notation,
T=CA=\left[ \begin {array}{cccc} 1&amp;0&amp;2&amp;3\\ \noalign{\medskip}5&amp;-2&amp;-2&amp;0<br /> \\ \noalign{\medskip}4&amp;5&amp;2&amp;-2\\ \noalign{\medskip}-1&amp;-2&amp;-2&amp;0<br /> \end {array} \right]\left[ \begin {array}{c} 5\\ \noalign{\medskip}0\\ \noalign{\medskip}<br /> -1\\ \noalign{\medskip}-6\end {array} \right] <br /> .
Now decompose the matrix C into four row vectors and select the first one from the left side and lablel it \beta=1. This will give T_1 as
T_1=(1)(5) + (0)(0) + (2)(-1) + (3)(-6) = -15.
This is wrong, because in C_{\alpha\beta}, \alpha and \beta represent, respectively, the row and column number so that C_{\alpha1}, would be a column vector, while you choose the row vector to have the matrix relation hold. While this sounds correct that the matrix representation gives the result as yours, but in tensor notation we are encountering number-by-number, i.e. component-by-component, multiplication not vector-by-vector multiplication!
AB
Thanks Altabeh, I understand that I am doing something wrong. Could you please show how the first value of 7 is obtained?
Thanks
Matt
Thanks
Matt
...so that, C_{\alpha1} would be a column vector...
This means that
C_{\alpha1}=\left[ \begin {array}{c} 1\\ \noalign{\medskip}5\\ \noalign{\medskip}<br /> 4\\ \noalign{\medskip}-1\end {array} \right].
Multiplying each component by the corresponding component of the vector A gives
T_1=(1)(5)+(5)(0)+(4)(-1)+(-1)(-6)=7.
Do a similar calculation to get other components of the vector T.
AB
The version on Google Books has C_{31}=-1 and C_{32}=-3 (excercise 2.9, 1), rather than -2 and -2.
Yes, you are correct. I do have the wrong values :redface:
Thanks a lot for the help. I didn't realize in the example problem you would get the same answer using the column as you would using the row.
Now it all makes sense.
Thanks a lot everyone.
Now I know why Fredrik thought I was calculating the tranpose of CA
Matt
I guess this is a little late, but if A is a 4×1 matrix, what we get from the definition of matrix multiplication is
(CA^T)_i=C_{ij}A^T_j=C_{ij}A_j
and
(AC)_i=A_jC_{ji}
