Second Harmonic Generation: Light Intensity & Efficiency
Second Harmonic Generation (SHG) effectively doubles the frequency of light by utilizing non-linear crystals. The efficiency of this process is highly dependent on the intensity of the input light beam. For optimal conversion, a high-intensity light source, such as a laser, is preferred over sunlight due to its coherent properties. The efficiency of conversion varies based on the crystal used and the intensity, with typical efficiencies ranging from 10% to 30% for well-optimized systems.
  • Understanding of Second Harmonic Generation (SHG)
  • Familiarity with non-linear optics
  • Knowledge of light intensity and its measurement
  • Basic principles of laser technology
  • Research specific non-linear crystals used in SHG, such as BBO or KTP
  • Study the relationship between light intensity and conversion efficiency in SHG
  • Explore laser systems suitable for SHG applications
  • Investigate methods for optimizing light collection from sunlight for SHG
Physicists, optical engineers, and researchers in photonics and laser technology who are interested in frequency conversion and non-linear optical processes.
brethg
OK so i know it is possible to double the frequency of a light beam by using second harmonic generation by passing the beam through a non-linear crystal; however i am unclear as to the required intensity of light beam that is needed to achieve efficient conversation. Would it be possible to collect (a lot of) sunlight, pass it through a prism, then pass the resulting infra red light through a non-linear crystal to convert it to green light?
Also if possible: What would the required intensity be? and what would the efficiency of conversion be?
If possible please supply references
no one?
can no one shed any light on this? :-)
  • · Replies 207 ·
16K
  • · Replies 20 ·
