Is the Second Moment of Area a Universal Property of Beams?
  • Thread starter Thread starter Iclaudius
    Area Moment
The second moment of area is a property dependent solely on the beam's cross-section, meaning it remains unchanged whether the beam is curved or straight, as long as the cross-section is uniform along its length. For a rectangular section, the formula I = bd^3/12 applies about the centroidal axis. Preloading the beam does not affect the second moment of area, provided the conditions of engineering beam theory are met. Key conditions include maintaining plane sections and ensuring deflections are small relative to the beam's length. Thus, the second moment of area remains a consistent characteristic of the beam's geometry.
Iclaudius
Hello my friends, so I am once again confused :frown:
Is the second moment of area a universal property of a beam i.e the beams cross section?
So what i mean to say is - if i have a beam and it is curved with a rectangular cross section, and take this same beam and ensure it to be now straight - will the second moment of area be the same in the two beams?
I = bd^(2)/2
where b =width
and d = depth
(let me know if my asking for help is poorly worded)
Appreciate the help,
Claudius
Yes, the second moment of area is only dependent on a 2-D section of the beam. As long as the cross-section is uniform along the length of the beam, you should be good to go.
For a rectangular section, I = bd^3/12 about the centroidal axis. Second area moments have units of L^4.
I'm confused about what you mean here.
Are you suggesting you apply some preload to straighten the beam longitudinally?
Your analysis will still be the same, with the same values for I so long as you remain within the conditions for engineering beam theory. That is a preload will not affect I.
The principal ones are:
Plane sections remain plane.
Deflections are small compared with the length.
And, of course, you add in the effect of any preload to your calculations.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
