Second Order Differential Equation (homogenous)
sandy.bridge
Given y_1(x)=x is a solution to (2x-1)y''-4xy'+4y=0, find y(2) given (y(1),y'(1))=(0, 0). Utilize method of reduction of order.
I need help with this as I end up getting some ugly (in my mind, anyways) integrals. Thanks in advance!
Let y=y_1v=xv, hence y'=v'x+v, and y''=2v'+v''x.
4xv'-2v'+2x^2v''-xv''-4xv-4x^2v'+4xv=0
4xv'-2v'+2x^2v''-xv''-4x^2v'=0
Let w=v'
After separating I get:
\frac{dw}{w}=\frac{4x^2-4x+2}{2x^2-x}dx
\frac{4x^2-4x+2}{2x^2-x}=2+\frac{A}{x}+\frac{B}{2x-1}
where A(2x-1)+Bx=-2x+2, hence (A, B)=(-2, 2)
Therefore,
\frac{dw}{w}=(2-2\frac{1}{x}+2\frac{1}{2x-1})dx
ln|w|=2x-2ln|x|+2ln|2x-1|+C_1
w=\frac{e^{2x+C_1}(4x^2-4x+1)}{x^2}
Next, I know I am supposed to integrate this to determine y', however, I am unsure of how to go about doing this.
You should be able to determine C1 at this stage from the initial conditions. The answer is rather interesting, but I'm not sure what the implications are.
Well, w=v'=\frac{y'-v}{x}=\frac{y'-y/y_1}{x}, however, the initial values causes this to fall to zero, so I am a little confused.
Exactly. A degenerate solution, perhaps?
My apologies. This is the first time I have seen this, and my textbook does not seem to mention anything regarding degenerate solutions. What exactly does this imply? Does that mean I assume v'=0 and start again?
It implies to me that with these initial conditions y will be always 0. That's certainly a solution.
Okay, let's say that y(1)=1 instead.
That results in -1=e^{2x+C_1} which is impossible, however, the example that I am looking at states that if y(1)=1 there is a solution. What sort of trick does one do after getting to this point, though? If it were zero I can see how that would indicate that v was a constant since v'=0. However, being that it is equal to -1 with y(1)=1, y'(1)=0, I don't quite see what that implies.
No, you correctly had ln|w| on the LHS, not ln(w).
Ah yes, don't know how that got away from me. Which brings me to C_1=-2. I still have to do a nasty integral to determine v do I not?
I believe that integral can be reduced/equated to integrating a double exponential. There's nothing special about the range, so it cannot be done analytically.
But how come you changed the b.c. from y(1)=0 to y(1)=1? Which is actually wanted?
There was both that I wanted to go over. Thanks for your help! Now that I know I cannot analytically solve that, I am done.
I have been notified that there is an error as this problem is indeed doable analytically. Here is my adjusted work, however, still seems rather tricky to solve:
Let w=v'
Therefore,
ln|w|+c_1=2x-2ln|x|+ln|2x-1|
From here we can utilize y'=v'x+v, since w=v' we have y'(1)=w(1)(1)+1 and w(1)=-1.
ln|-1|+c_1=2,c_1=2
Therefore,
v=\int\frac{e^{2x-2}(2x-1)}{x^2}dx
From here you can get the right answer by factoring out e^(-2) and applying integration by parts.
I got that far before, but it didn't seem like integration by parts would help. What I didn't consider was whether the nasty parts might cancel, so here goes:
##\int_1^2\frac{e^{2x}(2x-1)}{x^2}dx = 2\int_1^2\frac{e^{2x}}{x}dx - \int_1^2\frac{e^{2x}}{x^2}dx = 2\int_1^2\frac{e^{2x}}{x}dx + [\frac{e^{2x}}{x}]_1^2 - 2 \int_1^2\frac{e^{2x}}{x}dx##
Bingo.
e^{-2}[2\int\frac{e^{2x}}{x}dx-\int\frac{e^{2x}}{x^2}dx]=e^{-2}[2\int\frac{e^{2x}}{x}dx-\frac{e^{2x}}{x}-2\int\frac{e^2x}{x}dx]=-\frac{e^{2x-2}}{x}+c_2
I used U=e^{2x}, dU=2e^{2x}dx, dV=1/x^2dx, V=-1/x
From here I determined c_2=2,, and y(2)=-3.38906 which was the solution.
