Second Order differential equation involving chain rule
Woolyabyss
Solve (d^2x)/(dt^2) = 2x(9 + x^2) given that dx/dt = 9 when x = 0 and x = 3 when t = 0
v = dx/dt ...... dv/dx = d^2x/dt^2
dv/dx = v(dv/dx)
v(dv/dx) = 18x +2x^3
integrating and evaluating using limits and then you get
(v^2/)2 - 81/2 = 9x^2 +.5x^4
multiply by 2 and add 81 to both sides
v^2 = 18x^2 + x^4 + 81
dx/dt = v = + or - (18^2 + x^4 +81)^(1/2)
this where I have a problem generally when we did these questions I would be able to just get the root without needing to use the square root symbol. I'm not sure how to integrate polynomials with a power.Does this require integration by substitution? Because I know its no longer apart of our course.
Any help would be appreciated
dv/dx = v(dv/dx)
this where I have a problem generally when we did these questions I would be able to just get the root without needing to use the square root symbol. I'm not sure how to integrate polynomials with a power. Does this require integration by substitution? Because I know it's no longer a part of our course.
Any help would be appreciated.
##x^4 + 18 x^2 + 81## is a perfect square.
Oh right i didn't see that. So it would be ( x^2 + 9 )^2
and then when you get the square root (x^2 + 9)
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
