Seeking Advice on Small EE Project Ideas
A third-year electrical engineering student expresses disillusionment with their field due to a lack of practical application and difficulty finding internships. They seek advice on small projects to enhance their skills over the summer, showing interest in hardware neural networks and electroactive polymers but feeling constrained by budget and resources. Suggestions include prototyping neural networks in VHDL, collaborating with cognitive psychology programs for signal processing projects, and using Arduino microcontrollers for practical applications. The discussion highlights the importance of microprocessors in facilitating interesting projects and gaining hands-on experience. Engaging in small projects is seen as a valuable way to build confidence and skills in electrical engineering.
Neutronium
Hello,
I haven’t frequented this board in long while but right now I need some advice.
I’m currently a third year electrical engineering student (on an irregular course sequence) and quite frankly, I’m becoming disillusioned about the field I’ve chosen. It’s not that electronics or power engineering doesn’t interest me, but so far I feel like I cannot apply anything that I’ve learned into something productive.
What primarily led to this is that I’ve failed to find an internship in my specific field due to a lack of technical skills, and I suspect most EE students at my level who do succeed end up doing something software or basic technician tasks. Also, I notice that many of the software and computer engineering students have their own software projects, but practically no one in electrical engineering does. I may be wrong, but this is my perception of the situation so far.
There is a project course in the fall semester that might change things for the better; however I feel that doing a small electrical engineering project by myself or with classmates this summer would help me more. The problem though is that I’m not exactly sure what I want to do or if it can be done with the skills and resources I have. I am interested in hardware neural networks and applications of electroactive polymers, but I think neural networks might be out of the question for a small project and the electroactive polymers are probably out of my budget. I may have total access to my university’s IEEE student office for tools.
Are there any recommended projects?
Prototype your neural nets in VHDL and find the FPGA lab so that you can test it out on real hardware? Play with some software neural nets?
If you have a strong cognitive psychology program, hop on over to them and see if they wouldn't want an EE on board for a project or two. There's a lot of interesting signal processing work involving cognitive process. (Oh, and real neural nets.)
Otherwise, I like the arduinos for random small projects to do some practical EE work on the side. They're powerful, but cheap and easy to use micro-controllers.
Neutronium said:
Hello,
I know that feeling.
I found that microprocessors are the gateway to doing interesting little projects. They have outputs that you can use to control things and ADC's that you can use to measure things. Once you get the hang of it, programming them becomes easy. I used microprocessors to make a TV remote with a learning eye (it could copy codes from other remotes) and I made a digital voltmeter that stored data and sent it to my PC through a USB cable.
Take a look at http://www.sparkfun.com/commerce/categories.php" gear. They have full evaluation boards for lots of different chips. Maybe something there will inspire you to make a cool app. Good luck.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
