Seeking help for limit math problem
  • Thread starter Thread starter teffy3001
    Limit
teffy3001
lim (sqrt(x^2+5) - 3)/(x-2)
x->2
i hope that kinda makes sense...
anyways, my question is that I've been doing this and i keep getting 0 in the denominator in the answer...after subsituting everything i got 4/ sqrt(9) - 3 = 4/0
so then is this equation just not possible?
How did you get this? That doesn't appear to bear any relation to the initial expression you gave.
x->2
For \lim_{x \rightarrow 2}\frac{\sqrt{x^2+5}-3}{x-2}
Clearly the substitution method will give you a zero denominator!
So, what methods have you learned to try and "avoid" a zero denominator?
Casey
I think they meant (sqrt(4+5)-3)/0...
Arithmetic errors are always a good start:wink:
um the course I am taking told me first multiply the numerator and denominator by
sqrt(x^2+5) - 3
i might have done it wrong but then i got x^2+5-9/x-2(sqrt(x^2+5) - 3)
i factored that to x^2-4/x-2(sqrt(x^2+5) - 3)
and then eventually got (x-2)(x+2)/x-2(sqrt(x^2+5) - 3)
canceled out x-2
x+2/sqrt(x^2 + 5) - 3
then subtituted the x for 2
thats how i got that answer...i think that's how the teacher told me to do it...probably made mistakes along the way though..im not sure
sqrt(x^2+5) - 3
Where is the interaction term in your numerator? How do you expand (a + b)^2?
sqrt(x^2+5) - 3
canceled out x-2
Your on the right track by using the conjugate; however, you need to watch your signs
the conjugate of \sqrt{x^2+5}-3 is \sqrt{x^2+5}+3
Casey
PS~Do you understand why the sign needs to be a plus (+) sign?
Hint: (a+b)^2 does not = a^2+b^2
Casey
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
