Seeking suggestions for journals to publish paper
The discussion centers on an undergraduate student's project involving the simulation of elastic membrane deformation under specific forces and boundaries. While the student has invested significant time and believes the results are satisfactory, there is skepticism regarding the potential for publication in scientific journals. The consensus suggests that the work resembles a fundamental homework problem, which typically lacks the novelty required for journal acceptance. It is emphasized that scientific publication requires engagement with existing literature to ensure the work contributes meaningfully to the field. Without a unique approach or significant findings, the likelihood of publication is considered very low. Additionally, the discussion points out that many software tools can easily solve such problems, further diminishing the originality of the student's work.
Fin_de_Siecle
I am a undergraduate student now and I have joined in a project in my college. I was assigned a job to simulate the deformation of an elastic membrane given the boundary and the exerted forces on it. It seems to be a homework problem and quite fundamental, but I really have spent much time on it and the results seem okay. Is it possible there are some SCI journals might accept my work?
I'd appreciate a lot if you can list me some possible choices.
Thank you so much.
The usual answer is "whatever journal it fits in best, based on your reading". If you say, "but I'm not reading any", then your answer is usually 'nowhere'. If you don't know what else has been done in a field, it is highly unlikely that you have produced anything useful. Scientific publication is a dialog, and wanting to talk without listening is no more popular there than anywhere else.
That said, I suspect very, very few journals are interested in publishing answers to homework problems.
Fin_de_Siecle said:
It seems to be a homework problem and quite fundamental, but I really have spent much time on it and the results seem okay..
The amount of time you spent on it was, probably, a function of the amount of learning you had to do to solve it, not the intrinsic difficulty of the problem.
It would be fairly easy to list 10 commercially available software packages (not to mention open source software) that would give you a numerical solution to this. If your problem was straightforward to describe, it might take an experienced user say ten minutes to set it up and solve it. If it was hard, maybe half a day.
Unless there is something very novel about either your problem or the way you solved it, the chances of a journal publishing your work are zilch IMO.
Hey, I am Andreas from Germany. I am currently 35 years old and I want to relearn math and physics. This is not one of these regular questions when it comes to this matter. So... I am very realistic about it. I know that there are severe contraints when it comes to selfstudy compared to a regular school and/or university (structure, peers, teachers, learning groups, tests, access to papers and so on) . I will never get a job in this field and I will never be taken serious by "real"...
Yesterday, 9/5/2025, when I was surfing, I found an article The Schwarzschild solution contains three problems, which can be easily solved - Journal of King Saud University - Science ABUNDANCE ESTIMATION IN AN ARID ENVIRONMENT https://jksus.org/the-schwarzschild-solution-contains-three-problems-which-can-be-easily-solved/ that has the derivation of a line element as a corrected version of the Schwarzschild solution to Einstein’s field equation. This article's date received is 2022-11-15...
