Sensing-Electricity Questions Help
  • Thread starter Thread starter 123Sub-Zero
The discussion centers on two main electrical engineering questions regarding solar panels and thermistors. The first question involves determining the configuration of 720 solar cells to achieve a total emf of 15V, requiring calculations to find the values of x (series connections) and y (parallel connections). The second question seeks to derive an equation for the voltage across a resistor in a potential divider circuit with a thermistor, dependent on the resistor's value and the thermistor's resistance. Participants are encouraged to share their attempts at solving these problems for better guidance. The thread emphasizes collaboration and problem-solving in electrical concepts.
123Sub-Zero
I am struggling on the following questions and require help. Please reply as soon as possible.
1.720 cells are connected together to form a solar panel to power a remote telephone. The individual cells are connected in a grid of x cells in series and then these series lines joined in parallel with each other forming y parallel lines. What are the values of x and y to give an emf of 15V and using all 720 cells?
2.A thermistor is set up in a potential divider with a resistor R across a 5v power supply. A voltage is taken across the resistor R. Derive an equation for how this voltage depends on the value of R, the 5V and RTH
Thanks in advance!
If you show us how you tried to solve your problems and where you are getting stuck, we can attempt to steer you in a successful direction.
I recommend seeing this https://www.physicsforums.com/showthread.php?t=94379
