Separable Equation with Condition?
silicon_hobo
[SOLVED] Separable Equation with Condition?
Solve.
http://www.mcp-server.com/~lush/shillmud/int3.71.JPG
I'm not sure how to separate this. Also, since the directions consist of only one word, I'm not sure if y(2)=2 is some kind of hint or an additional condition to be fulfilled. I'm wondering where to go after factoring t out of the top. Thanks.
http://www.mcp-server.com/~lush/shillmud/int3.72.JPG
Well after factoring... you separate (hence separable equations!)
\frac{dy}{y+3} = \frac{t}{t^2+1}dt
Then integrate both sides.
y(2) = 2 is an initial condition, not a hint... After solving for y(t) you will have one arbitrary constant, which can be solved for using this condition.
Wow, that seems almost too easy. Thanks.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
