Separating Electricity and Magnetism from EM Waves
Electricity and magnetism are unified in Maxwell's equations, and separating them from an electromagnetic wave would effectively destroy the wave. Removing either the electric or magnetic field component leads to the breakdown of the electromagnetic field. Jefimenko's Equations illustrate the coupling of electric and magnetic fields produced by time-varying sources. At very low frequencies, the fields can become decoupled, allowing for the potential removal of one component with minimal impact on the other. However, in general, the two components are inherently linked in electromagnetic waves.
mathsTKK
Electricity and magnetism had been unified under Maxwell's four famous equations. But I wonder if there any method to separate the this two components from an EM wave?
Will there be any effects if this two components are separated?
Hope you all can help me to solve this problem^^
Thank you for kind assistance :)
No. If you were to "remove" (that is zero out the field) either the electric or the magnetic field component from an electromagnetic wave then you end up destroying the wave. If you want to see how the two are coupled explicitly, you can look at Jefimenko's Equations. Jefimenko's Equations show the excited electric and magnetic fields from a given set of sources. Any time-varying sources produce both electric and magnetic fields. If you were to "remove" one of these components the electromagnetic field has to break down. The two fields do become decoupled at very low frequencies and here you could destroy one of the fields without too severely affecting the other (over a reasonable set of distance).
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
9K
