Separating ions. Acceleration problem
  • Thread starter Thread starter Triple88a
    Acceleration Ions
The problem involves separating two types of ions, fast and slow, which travel at different speeds through charged plates. The setup includes two plates with a specified distance and charge, and the goal is to determine the required acceleration to achieve a specific separation between the ions after they exit the plates.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the time each ion spends traveling through the plates and how this affects their deflection. There are attempts to calculate the time taken for each ion to traverse the distance between the plates and considerations of how to apply kinematic equations to find the necessary acceleration.
Some participants have provided feedback and suggestions on how to approach the problem, including the importance of understanding the time of travel and the forces acting on the ions. There is ongoing exploration of the relationship between the ions' velocities and their resulting positions after exiting the plates.
Participants are navigating the complexities of the problem, including the need to account for different velocities and the resulting trajectories of the ions. There is mention of the specific requirement for a 2 cm separation at a distance of 50 cm, which adds to the constraints of the problem.
Triple88a
You are trying to separate 2 types of ions (fast and slow). The fast ones travel at 1000m/s and the slow ones travel at 100m/s. At the beginning you have 2 plates. One has + and the other one has negative charge. The size of the plates is 5cm and they are 3 cm apart. What will the acceleration have to be between the 2 plates that will put the fast and slow ions 2 cm apart at 50cm once out of the plates.
Remember once the ions are out of the plates, they will not accelerate any more.
I drew it out.
The reds are the ions. The blue box at the bottom is the emitter. The 2 gray ones are the charged plates that will accelerate the ions.
From what i know there will be 2 different times since the ions travel at different speeds
For the fast one i calculated
.5m / 1000m/s = .0005s
for the slow one i got
.5m / 100m/s = .005s
From here on out, I'm stuck and have no idea what to do next.
Thanks in advance.
The key is how long the fast or the slow will be traveling through the plates..
By establishing a charge between the plates, they will be traveling across the 5 cm distance and will be accelerated (deflected) according to normal kinematics. The slower ones being between the plates will be subjected to an accelerating force for a longer interval and hence will be deflected more.
Start with how long each will be traveling across the plates and see what occurs to you remembering that as usual F = m*a.
Thank you for the feedback sir. So i got that. 5cm = .05 m
Since their initial velocity is in the Y direction during the acceleration towards X will not change the Y, I do this to find their times.
Fast = .05m / 1000m/s = .00005s
Slow = .05m / 100m/s = .0005s
Then i don't know where to plug it in or how. Where does the 2cm difference end up going?
I assume I'm going to have 2 equations. One for the acceleration here and another once its out of the plates but i have no idea what formulas to use.
Since both are going to curve, i don't know what the angle in between will be which is where I'm confused.
I've never done a problem like this before so I'm confused what to do next.
The 2 cm distance is at 50 cm.
What component of velocity is required to get the slow ion to move farther to the right by 2 cm by the time it reaches 50 cm than the fast one?
You know V = a*t where t is the time the particle is subjected to acceleration between the plates.
That velocity times the time T to get to 50 cm at the original speed then would be the deflection I'd think for each particle. The additional constraint will be that 1 is 2 cm further along when it gets there. One distance to the right will be 2 cm more than the other.
alright so here is what i got.
position after the .05m (between plates) is
Xf = 0ms + 0t + .5At^2
slow beam..
Xfs = .5a(.0005s^2)
fast beam
Xff = .5a(.00005s^2)
Next velocity at the end
Slow beam
Vfs = a*.0005s
Fast beam
Vff = a*.00005sNext, X2-X1 = .02m
so
.02m = (.5a(.0005s^2) + (a*.0005s)*.005) - (.5a(.00005s^2) + (a*.00005s)*.0005)
A = 7696.00 m/s^2
