Engineering Solving Series LR Circuit: Calculate Wattless & Power Components
A series LR circuit with a self-inductance of 0.7 Henry and a resistance of 5 ohms is analyzed for wattless and power components when connected to a 200-volt supply at 50 Hz. The power component of current is defined as I(1)cos(theta), while the wattless component is I(1)sin(theta), where I(1) is the RMS current and theta is the phase difference between current and voltage. The discussion emphasizes the importance of plotting the complex impedance vector in the complex plane to understand the relationship between resistive and reactive components. By calculating the complex impedance, one can visualize how the total power relates to the resistive portion of the circuit. The explanation clarifies the concepts of power and wattless components in the context of AC circuits.
Amith2006
1)A coil of self inductance of 0.7 Henry is joined in series with a non inductive resistance of 5 ohms. Calculate the wattless and power components as well as total current when connected to a supply of 200 volts at frequency of 50 cycles per second.
It is given in my book that the power component of current = I(1)[cos(theta)]
Where I(1) = Root Mean Square value of total current in the circuit
I think theta is the phase difference between current and voltage in circuit
Also they say that the wattless component of current = I(1)[sin(theta)]
Could somebody please explain, what is the concept behind this?
I'm not familiar with those exact terms, but I think I can see what they are driving at.
Try this -- plot the complex impedance vector in the complex plane, with the real (resistive) axis on the horizontal and the imaginary (reactive) axis on the vertical. Calculate the complex impedance looking into the series combination of the L and R, and plot that as a vector in this 2-space. The horizontal component is just the resistance, and the vertical component is the reactive impedance of the inductor at that frequency. So if you have the total power as P = |Z| I(1), then it would make sense what they are saying about the cosine component being the portion across the resistor. Does that work out?
I got your point.Thanks buddy.:smile:
12K
