Finding Volume Using Shell Method: x=3y-y^2
gwoody_wpcc
Have to find the volume using the shell method using the given curves
x=3y-y^2 and the y-axis about the x-axis
I know to use the equation V=2pi Integral y f(y) dy but no idea where to get the high and low limits for the integral
Have you graphed the equation x = 3y - y^2? Its graph is a paraboloa that opens to the left. You can find the vertex of the parabola by completing the square in the y terms.
Your typical volume element is \Delta V = 2\pi*y*x*\Delta y. Since you will be integrating with respect to y, you need to replace x in this formula with 3y - y^2. From the graph you can also get the limits of integration.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
