Shifting a double-wide variable - bit twiddling
  • Thread starter Thread starter CRGreathouse
    Bit Variable
The discussion focuses on efficiently shifting a double-wide variable stored in two parts, left and right, for high-performance applications requiring over 1e12 shifts. The initial method proposed involves a right shift of 2 using five operations and two assignments. Concerns are raised about the efficiency of large shifts, particularly a shift of 62 bits, and whether modern processors handle such shifts efficiently compared to older ones. Suggestions include using a switch statement for precomputed shifts and optimizing the operation count. It is noted that replacing the addition with a bitwise OR may be beneficial, as it simplifies the operation and could potentially enhance performance. Overall, the conversation emphasizes the need for efficient bit manipulation techniques in programming for performance-critical applications.
CRGreathouse
Shifting a double-wide variable -- bit twiddling
I have a number too long to fit into the largest variable size (unsigned long long, 64 bits in this case) so I'm storing it in two variables, left and right. I want to shift it -- and to do it quickly, as I'll do this more than 1e12 times.
The 'obvious' way is
Code:
unsigned long long right, left;
right = ((left&3) << 62) + (right >> 2);
left >>= 2;
for a total of 5 operations and two assignments. This example is a right shift of 2, but right shifts by 1 and 4 are also important. In any case the size of the shift should be known at compile time.
1. Is a shift of 62 too large to be done efficiently? I know that older processors used to take O(n) time to shift n places (something like 3+n micro-ops), but I don't know if this holds on modern processors. Perhaps I should make a switch statement with constant to add (1 << 62, 2 << 62, and 3 << 62 precomputed)? Or would the branch misprediction outweigh this?
2. Is there a way to do this with fewer operations? I'm sure there are some people out there who have been doing bit manipulations far longer than I have.
For what it's worth I'm on a Core Duo, but I'm hoping for improvements to my program that work on most systems.
Technology news on Phys.org
You can replace "(left&3)" with just "left" since the bit mask operation is redundant given the left shift. It cuts your cost down to 4 operations.
I would also replace the "+" operator with a bitwise OR instead. You are not adding values but combining bits. It may not actually save any execution time, but a "|" is simpler than a "+" operation so there is a remote chance that it is faster on some systems.
right >>= 2;
right |= left << 62;
left >>= 2;
Ooh, thanks. That does help.
Dear Peeps I have posted a few questions about programing on this sectio of the PF forum. I want to ask you veterans how you folks learn program in assembly and about computer architecture for the x86 family. In addition to finish learning C, I am also reading the book From bits to Gates to C and Beyond. In the book, it uses the mini LC3 assembly language. I also have books on assembly programming and computer architecture. The few famous ones i have are Computer Organization and...
I have a quick questions. I am going through a book on C programming on my own. Afterwards, I plan to go through something call data structures and algorithms on my own also in C. I also need to learn C++, Matlab and for personal interest Haskell. For the two topic of data structures and algorithms, I understand there are standard ones across all programming languages. After learning it through C, what would be the biggest issue when trying to implement the same data...
