Shifting the origine of time in isotropic oscillator
esradw
I am really lost here :(
The equation of motion X(t)=Ax Cos(wt-delta(x))
Y(t)=Ay Cos(wt-delta(y))
by shifting the origine of time ( t'=t+to where I need to figure out what is appropriate for time to ) and ( Delta=Delta(y)-Delta(x) )
I am suposed to find X(t)=Ax Cos(wt) and Y(t)=Ay Cos(wt-Delta)
I wish I could give some of my work but I can't even start it right now since I cannot think of the appropriate time (to) for X , I know that it can not be 0 because then I come to the same point again.
anyhelp appreciated
thanks
I think you mean for the argument of that last function you gave to be t'. What do you get when t'=0? Compare this to what you get with the original function at the same time as measured in t (ie, in terms of to).
Yes t to be t' but in the question itself says once you find the solution with t',convert it into t .
I thought I can give to= dx/w then my equation become for X=Ax Cos( wt'-(wto+Deltax)) and when I unpack it, X/Ax=Cos(wt')Cos(dx+Deltax)+Sinwt' Sin(dx+Deltax) that has to stay only X/Ax=Cos(wt') how to come to this conclution ? How to get red of Cos(dx+Deltax))+Sinwt' Sin(dx+Deltax) I don't know :((((((
any idea?
I figured it out
thanks again
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
