What type of signal should I use for limiting range to 600ft?
  • Thread starter Thread starter Lucille2
    Range Short
To limit a signal's range to 600 feet, several factors must be considered, including frequency, transmit power, antenna type, and height. It is challenging to restrict a transmitter's range precisely, but techniques exist to minimize reception beyond the desired distance. The purpose of limiting the range, whether for security or to prevent interference, significantly influences the approach taken. Understanding the specific application, such as whether the signal operates on a broadcast band or is intended for a localized area, is crucial. Exploring these parameters will help determine the most effective signal type for the project.
Lucille2
Hello guys,
I am totally new to EE and in need of info on a project I am working on. I am trying to broadcast a short range signal and the distance the signal can travel needs to be limited.
So let's say I want the signal to reach up to 600ft. I need it not to be easily received by other receivers at distances past that. I was just wondering if that even exists or what type of signal I should use, radio or otherwise.
Feel free to send me elsewhere too if this is not the proper forum to be asking these beginner questions.
Thanks
There are a lot of considerations in such a project besides range. One of the considerations is frequency. Will it be operating on one of the broadcast bands? Is this to be a campus based transmitter to broadcast only on campus?
Generally its very difficult to limit the range of a transmitter to a specific distance but there are a number of techniques that can be tried. It is important to know the frequency band, the transmit power, the antenna type and the antenna height you plan to use.
Please specify why you need limited range: security or interference or ? The respective solutions are vastly different.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
