Show that [J_a,G_a] = 0, commutation relationships
ma18
Using the given equations prove that
,[/B]
(it won't render together in Maple for whatever reason)
So I started with expanding the Jacobi Identity (the third relevant equation) and through tedious algebra arrived at proving it unnecessarily and then finding that
then by applying the second equation this goes to
I am unsure how to proceed from here however.
The question also gives the hint that the trick to solve it is to take the appropriate particular values of the labels a,b,y in the Jacobi identity but I am unsure how to use this.
Any help would be greatly appreciated.
You're not actually given ##[G_a,G_b]##, so it's a bit of a hassle to use that Jacobi identity. Try to find a way to relate ##[J_a,G_b]## to the expression ## [ J_a, [J_b,J_c]]## and use the Jacobi identity for that.
Hmm okay, tbh I'm not sure how to proceed with that
To push you along, consider
$$ {\epsilon_a}^{bc} [J_b,J_c] = i {\epsilon_a}^{bc} {\epsilon^d}_{bc} G_d.$$
Using an identity for the Levi-Civita symbol will give you an expression for ##G_a## in terms of the commutator of ##J##s.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
