Showing properties of Ordered Fields
  • Thread starter Thread starter mliuzzolino
    Fields Properties
mliuzzolino
Let S = {(a, b): a, b \in \mathbb{Z} and b ≠ 0}. An equivalence relation "~" on S is defined by (a, b) ~ (c, d) iff ad = bc.
1) For any b \in \mathbb{Z} \setminus {0}, show that [0/b] = [0/1] and [b/b] = [1/1].
2) For any a, b \in \mathbb{Z} with b ≠ 0, show that [a/b] + [0/1] = [a/b] and [a/b][1/1] = [a/b].
1) First, show that [0/b] = [0/1].
For any value of b not zero, [0/1] is contained in the equivalence class when b = 1: Eb = {[0/b]: b ≠ 0}. Therefore, [0/b] = [0/1].
Next, show that [b/b] = [1/1].
For any value of b not zero, [1/1] is contained in the equivalence class when b = 1: ESUB]b[/SUB] = {[b/b]: b ≠ 0}. Therefore, [b/b] = [1/1].
2) First show that [a/b] + [0/1] = [a/b].
[a/b] + [0/1] = \frac{a*1 + 0*b}{b * 1} = \frac{a + 0}{b} = [a/b].
Next, show that [a/b][1/1] = [a/b].
[a/b][1/1] = \frac{a(1)}{b(1)} = [a/b].
For 1), I'm not exactly sure that I'm doing this correctly. It seems like I should be using this equivalence class as the argument, but I'm not sure I set it up correctly.
For 2) this seems too simple. Am I missing something? Should I be adding the axioms used at each step?
They seem to be switching notation. I think when they write [0/b] they should actually be writing [(0,b)], which is the set of all pairs (c,d) such that (c,d)~(0,b) or c*b=d*0. Similarly [(0,1)] is the set of all ordered pairs (c,d) such that (c,d)~(0,1) or c*1=d*0. So what you have to show to show [(0,b)]=[(0,1)] is that c*b=d*0 iff c*1=d*0 when b is not zero.
I'm going to assume that the notation [0/b] refers to the equivalence class that contains the element (0, b), since this "/" notation is not defined in your post, but is probably what is intended. Question 1 is asking you to show that [0/b] is equal to the equivalence class [0/1] for every (each) value of b except 0. So, in other words, one of the statements that your proof must apply to is that the equivalence class [0/2] is equal to the equivalence class [0/1]. Your proof does not show this.
I now understand that [b/b] is (b, b).
Let's say I try 1) again and try to show that [0/b] = [0/1].
This is equivalent to, show that (0, b) ~ (0, 1).
Can I do this by using the defined equivalence relation? (a,b) ~ (c,d) iff ad = bc?
Then (0, b) ~ (0, 1) would equal 0*1 = b*0. Then 0 = 0 which is true.
Does this show that [0/b] = [0/1]?
For 2) would it be something like..
(a, b) + (0, 1) = a/b + 0/1 = (a*1 + 0*b / b*1) = (a + 0)/b = a/b => (a, b)?
I apologize if I'm doing this entirely wrong. It just makes no sense to me.
This is a pretty sloppy presentation of a problem. No wonder you are confused. They should really have given you an addition rule for ordered pairs, or at least asked you to figure one out given that you want to add them like you add fractions. So sure, you ought to define (a,b)+(c,d)=(ad+bc,bd). What you are doing is correct.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
