SI Notation for Direct Current and Voltage Direct Current - Correct Usage?
  • Thread starter Thread starter nathanlee52
    Dc Notation Si
The discussion centers on the correct SI notation for Direct Current (DC) and Voltage Direct Current (VDC). While DC and VDC are commonly used abbreviations, the proper SI notation for current is represented by the letter "I" and for voltage by "U." The IEEE recommends using "Vdc" for volts in direct current and "Vac" for volts in alternating current, with lowercase "dc" and "ac" for text abbreviations. The terms "direct current" and "alternating current" describe the direction of current flow rather than its intensity. For scientific accuracy, adherence to SI notation is essential, and consulting recognized standards is advised.
nathanlee52
Hi,
Looking for the SI Notation practices for Direct Current and Voltage Direct Current. We commonly use DC and VDC, but I wonder if that's correct per SI.
I've looked through several guides and pdf's of SI Notation, and haven't yet been able to find the answer. Any help you can provide would be appreciated.
Thanks!
It sounds a bit weird when you say 'Direct Current' and 'Voltage Direct Current' even though DC does stand for Direct Current. I suppose its the whole technicality and ATM Machine argument.
DC Current SI unit is Ampere http://en.wikipedia.org/wiki/Electric_current" which is the same for AC Current.
DC Voltage SI unit is Volts http://en.wikipedia.org/wiki/Voltage" which is the same for AC Voltage.
Thank you Zryn for your input and for the effort to link the wiki pages.
The SI system of unit uses the following notation:
Volts: V or volts (lower case) with a space after a quantity (e.g., 230 V or 230 volts)
Amperes: A or amps (lower case) with a space after a quantity (e.g., 22 A or 22 amps)
The IEEE recommends the following notation:
Volts in direct current: Vdc
Volts in alternating current Vac
Abbreviation of direct current in text: ac (lower case)
Abbreviation of alternating current in text: dc (lower case)
BTW, the terms "direct current" and "alternating current" do not refer to the intensity in amperes, but to the fact that the current does not change direction (dc) or does change direction (ac). Hence, it is fine to say "volts direct current" or "volts alternating current".
Alternatively (no pun intended), we could come up with new terms that do not use the word "current", such as "same polarity" and "alternating polarity". However, I think that most people will stick with "ac" and "dc".
I can confirm that the correct SI notation for Direct Current is I (capital letter "i") and for Voltage Direct Current is U (capital letter "u"). The use of DC and VDC is commonly used in everyday language and is an accepted abbreviation, but for scientific and technical purposes, it is important to use the proper SI notation. This ensures consistency and accuracy in measurements and calculations. I recommend referring to recognized sources, such as the International System of Units (SI) or the National Institute of Standards and Technology (NIST), for further guidance on SI notation.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
