Solving SI Unit Analysis: Force & Area
In summary, the conversation discusses the concept of drag force and its relationship to surface area and velocity, as well as the units of force and the constant C. In order to determine the units of C, the equation F = CAv2 is rearranged and substituted with units to simplify. The correct units for C are N*s2/m4. In the second part, the equation F = kA is used to demonstrate dimensional analysis and determine the units of k, which are N/m2 or kg/(m*s2). The conversation also mentions the importance of rearranging equations when solving problems.
Nirupt
35
When an object falls through air, there is a drag force that depends on the product of the surface area, A (m2), and the square of the velocity, in (m/s). The equation is Fdrag = CAv2. The metric unit of force is the Newton, or (N). 1 N = 1 kg*m/s2. What are the units of the constant C?
and
Given the equation F =kA, where F is a force, k is a constant, and A is area, use unit analysis to determine the units of k.
Answer choices for the first:
m*s2/N
m*s2/N4
N*s2/m4
N*s/m2
Answer choices for the second:
N*m2, or kg*m3/s2
N/m2, or kg/(m*s2)
m2/N, or m*s2/kg
N*m, or kg*m2/s2
I'm just having trouble starting this class out, and I'm sure this stuff is simple but I'm being thrown off by the steps and my teacher is pretty disorganized but his explanations are confusing me. I would love information and steps on how to solve this.
First step would be to rearrange each of your equations for the quantity you want the units for. What exactly is it you find difficult? Dimensional analysis is used so that the units on both sides of an eqn check out. (I.e think of it like 'you can only equate a vector with a vector'. Similarly, a force can only equal a force, etc.. so units on left = units on right)
Just rearrange the equation: F = CAv2; C = F/(Av2).
Then substitute for F etc. using the units as though they were algebraic variables:
C = (kg m s-2)/(m2 (m/s)2)
and simplify.
Wow.. for some reason I was forgetting to rearrange the equation which is the first step.. lol sorry I was just over thinking it.
As a scientist, it is important to have a strong understanding of units and their conversions in order to accurately analyze and solve problems. In this case, we are dealing with force and area, which are both fundamental physical quantities and have their own respective units. The first step in solving this problem is to identify the given information and the desired units.
In the first question, we are given the equation Fdrag = CAv2, where Fdrag is the drag force, C is a constant, A is the surface area, and v is the velocity. We are also given the units for force (N) and area (m2). The question asks for the units of the constant C. This means we need to find the units that will cancel out the units of force (N) and area (m2) in the equation Fdrag = CAv2.
The second question gives us the equation F = kA, where F is a force, k is a constant, and A is the area. We are asked to determine the units of k. This means we need to find the units that will cancel out the units of force (N) and area (m2) in the equation F = kA.
To solve these problems, we can use dimensional analysis, which involves converting units to a common system and then canceling out the units to find the desired units. In this case, we will convert all units to the SI system (meters, kilograms, and seconds).
For the first question, we can start by converting the units of velocity (in/s) to the SI unit of meters per second (m/s). We know that 1 in = 0.0254 m, so we can write the conversion as:
1 in/s = (0.0254 m)/s
Next, we can substitute this conversion into the equation Fdrag = CAv2 and cancel out the units of velocity (s) to get:
Fdrag = C(0.0254 m/s)2
Next, we need to cancel out the units of area (m2). We can do this by dividing both sides of the equation by the unit of area (m2):
Fdrag/m2 = C(0.0254 m/s)2/m2
Simplifying this, we get:
Fdrag/m2 = C(0.000645 m2/s2)
Finally, we can cancel out the units of force (N) by
1. What is the SI unit for force?
The SI unit for force is Newton (N).
2. How do you calculate force using SI units?
Force can be calculated by multiplying mass (kg) by acceleration (m/s^2), which gives the unit of Newton (N).
3. What is the SI unit for area?
The SI unit for area is square meter (m^2).
4. How do you convert units of force and area to SI units?
To convert units of force to SI units, you can use conversion factors such as 1 lb = 4.45 N or 1 dyne = 0.00001 N. To convert units of area to SI units, you can use conversion factors such as 1 in^2 = 0.000645 m^2 or 1 ft^2 = 0.0929 m^2.
5. Why is it important to use SI units when solving force and area problems?
SI units provide a standardized system of measurement that is used globally in science and engineering. Using SI units ensures that calculations are accurate and consistent, and makes it easier for scientists to communicate and compare their results.
