Simple 555 timer circuit needed.
A user is seeking a simple LM555 timer circuit that activates after a switch is held down for one second, essentially a reverse of typical monostable circuits. They are looking for guidance on how to achieve this functionality, including using a push button on the trigger pin to initiate the cycle. Suggestions include utilizing a dual 555 timer (the 556 chip) to create a delay before pin 3 goes high if the switch remains depressed. The user is confident in handling the circuit reset but needs assistance with the initial setup. Overall, the discussion focuses on creating a delay mechanism using the LM555 timer.
ThisIsMe
Hi all, great forum here. Hope to learn a lot.
I am looking for a sample LM555 circuit. In simple terms I am looking what I think to be a reverse of the monostable circuits I have seen.
More or less I have a switch that needs to be held down for 1 sec before the circuit is active (pin 3 high on the LM555). Or is there another circuit? I think the 555 would do what I need, just need a sample circuit to bump me in the right direction.
Reseting the circuit I think I can handle, but just need a simple circuit to get me there.
Any help would be greatly appreciated.
You could put a push button on the trigger pin to signal a start of a cycle.
That is sort of what I a doing now. The switch needs to be held down for one second and then before pin 3 goes high.
If that makes better sense.
You might want to check into the 556 chip. It's a dual 555 timer. See if you can use one to trigger the other after 3 seconds if the switch is still depressed.
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
