Simple algebra problem (fields)
  • Thread starter Thread starter nowits
    Algebra Fields
nowits
[SOLVED] Simple algebra problem (fields)
Solve x²+x+41=0 in the fields Z43 and Z167
2. The attempt at a solution
Well Z43={0,1,...,42} so any y that is n=0 mod 43 works...
x²+x+41=0=43 -> x²+x=2 -> x=1
Is this how it's done or am I doing it incorrectly?
If the solution above is right, then what about the same equation in the field Z167? I can't find any x that is in that field and solves the problem.
Don't be intimidated by the fact you're working in a finite field! It's just a quadratic equation, and you've known how to solve them for a long time!
Huh? y? n?
The first implication is correct (and it's an "if-and-only-if"), but you have the second one backwards. x=1 is one solution to that quadratic, but you have not proven it is the only solution.
How would you normally solve x2+ x- 2= 0? What are its roots? What do negative numbers correspond to "mod 43"?
Thanks for your answers.
But I still don't get it for Z167:
x²+x+41=167
x²+x-126=0
x=\frac{-1\pm\sqrt{1-4\cdot 1\cdot(-126)}}{2}
The only way I get a reasonable result from that is if (under the square root):
1-4*1*(-126)=505=4
or: -126=41 => 4*1*41=164 => 1-4*1*(-126)=1-164=-163=4
or: -4*1*(-126)=504=3 => 1-4*1*(-126)=1+3=4
x=\frac{-1\pm\sqrt{4}}{2}=\frac{-1\pm 2}{2}
But then neither of the possible values of x is in Z167.
You're working in Z167, so shouldn't you use its division operator, rather than the division operator for rational numbers?
Yes, right.
I tried that but got a result that didn't solve the equation so I thought that my approach was wrong.
I tried it once again and this time got a result that works.
Ok, I've got it.
Thanks!
