Cross Product of Two Vectors - Mag. 2 & 4
In summary, vectors with mag 2 pointing East and mag 4 pointing 30 degrees west of North have the same magnitude, but the angle between them is different.
Zsmitty3
46
One vector with mag 2 pointing East. Other one is mag 4 pointing 30° west of North
Would you use sin or cos and would it be - or +
I did (2*4)cos60°=+4 because they're vectors and we have the A/H sides.
I'm worried about that though because we may use sin? Also Cos is (-) in the II quadrant so it could be negative?
If vectors have magnitude a and b, and the angle between them is C, then is the magnitude of the cross product ab cos C or ab sin C?
What is the angle between the vectors here?
Cross product is not commutative. Changing the order changes the sign. Which sign it takes depends on convention (right hand rule - see http://en.wikipedia.org/wiki/Cross_product).
Okay. So the angle between the two is going to be 60 degrees because the northbound one is going 30 west of N. The other's going east. If the North on was going straight N they would make a 90 degree angle. Since it's 30 degrees west of that (to the left) they're going to make a 60 degree angle. How can you tell the order when it doesn't specify which vector is A and which is B? Also, how do you determine whether it's cos or sin?
No, 60 degrees is wrong.
Yes, correct.
Again, no. You combined the 90 degrees with the 30 degrees in the wrong way. Draw a picture. Hint: west and east are opposite directions.
This is presumably made clear in your *actual* problem statement, which you did not post.
For the cross product, only ONE of these is correct, always. Look up the definition of the cross product to see which one.
Ok so I just drew it wrong. It's actually 8sin(120) which gives you the same answer. The 2m vector is listed first so do you just assume it's A?
The angle is 120 measuring anticlockwise from the first vector. The right-hand rule says align RH thumb with first vector, index finger with second vector, and middle finger indicates direction of result. That's towards you, which is the positive direction, so yes it's 8 sin(120o). Note if the angle had been 210 degrees all of that would still have applied, giving 8 sin(210o) towards you, i.e. 8 sin(150o) away from you.
1. What is the formula for calculating the cross product of two vectors?
The cross product of two vectors, A and B, is calculated using the formula A x B = (Ay * Bz - Az * By, Az * Bx - Ax * Bz, Ax * By - Ay * Bx). This results in a vector that is perpendicular to both A and B.
2. How do you find the magnitude of the cross product of two vectors?
The magnitude of the cross product of two vectors, A and B, is found using the formula |A x B| = |A| * |B| * sin(theta), where theta is the angle between the two vectors. This calculates the length of the resulting perpendicular vector.
3. Can the cross product of two vectors be negative?
Yes, the cross product of two vectors can be negative depending on the orientation of the vectors. If the resulting vector points in the opposite direction of the right-hand rule, then the cross product will be negative.
4. What is the significance of the cross product in physics and engineering?
The cross product is used in physics and engineering to determine the direction and magnitude of a force resulting from two vectors. It is also used in determining torque and magnetic fields in electromagnetism.
5. How is the cross product related to the dot product?
The cross product and the dot product are two different ways of multiplying vectors. The cross product results in a vector, while the dot product results in a scalar. Additionally, the cross product is used to find the perpendicular vector, while the dot product is used to find the projection of one vector onto another.
