DIY Capacitor: Create a Simple DIY Capacitor with Supermarket Supplies
In summary, the conversation discusses the creation of a DIY capacitor using materials from a supermarket. Suggestions are given for maximizing the capacitance, including using mylar film or saran wrap as an insulator and carefully rolling the layers together. The capacitor will be tested for DC shorts at 30V in a contest. Ways to maximize the capacitance include choosing an insulator with high permittivity, increasing the overlap area, and decreasing the width between the foils.
cakmano
Hi,
I am currently working on a small project to create an simple DIY capacitor with stuff that you can get from the supermarket. Probably, I will alternate with two aluminum foils and two insulators like plastic each other, and wrap them together. Do anyone have suggestion how I can maximize the capacitor that I will constructed within a toilet roll? What is the affordable and best insulator that I may get from the store?
Thanks
Welcome to PF
mylar film would probably be the best and easiest to obtain
See what others suggest :)
Dave
cakmano said:
Hi,
Thanks
Not a clue. But please keep us up to date on your research. I've been wanting to make a Saran wrap/aluminum foil capacitor for quite some time now.
davenn said:
Welcome to PF
Dave
Do you think mylar film will be better choice rather than saran wrap or wax paper?
I will post some update once I did it. But before that, I wish to get some more feedback on what insulator layer that I should use in order to maximize the capacitance. Up to this point, I am considering saran wrap, mylar film, and wax paper. Do you have any suggestion about that?
Thanks
Possibly but can you buy Mylar from a supermarket? 'Cling film' will be fine as long as you are careful not to puncture it with wrinkles in the aluminium foil. For a high capacity you need as close a spacing between the capacitor plates and as big an area as possible. That means a lot of care to keep the foil un-kinked and rolled up as carefully as possible.
I would recommend cutting lengths of foil and film and winding them on three individual 'bobbins' first and then you have the best chance of rolling them all together neatly and tightly into a cylinder. You MUST avoid a Short Circuit between the layers at all costs. Make the dielectric layer a bit wider than the two aluminium layers to allow them to wander a bit without touching.
Thanks for the reply, sophiecentaur.
I am referring the saran wrap as the Cling film actually.
What do you mean by "cutting them on three individual 'bobbins' first and then you have the best chance of rolling them all together neatly and tightly into a cylinder"?
By putting more insulator layer between the foil(let say 3 layer of cling film between the foils), do you think it will increase the capacitance?
Thicker insulation between the layers lowers the capacitance (but raises the withstand voltage). What voltage are you going to use this DIY capacitor at? How will you measure the capacitance? Is this for some contest? :smile:
You r right, its sort like for contest. Capacitors will be tested for DC shorts using a precision LCR meter after the submission. The capacitor should stand 30V. Do hve any suggestion how to maximize the capacitor itself?
Thanks
Thanks
Since it is a contest, what do YOU think are ways to maximize the capacitance?
C=E *A / d
There are 3 ways, choose insulator with the highest permittivity, make bigger overlap area, and decrease the width between two foils. In this case, I am thinking to make bigger area and connect the capacitance in parallel. At the same time, I am still wandering what insulator layer that should I use.
cakmano said:
C=E *A / d
Good. Sounds like some simple experiments could go a long way in helping you choose a dielectric material. Do you have access to the LCR meter for experiments? How about a 30V power supply? What kind of experiments would you do to figure out how best to put your project capacitor together?
That is the thing, there will be a special time where student can test their capacitance during the day. Outside of that, I am not sure how to test this capacitor. What I am thinking now is to build few different capacitors and bring it during the scheduled testing time. I will probably prepare different set of capacitors with insulator between the foils, and tested the capacitance. At this point, I will not have to roll those up, since it's just a test.
Do you think my basic idea about connecting the capacitor in parallel is okay? And do you think that I only have to work with what is the best insulator layer that I should use? Or is there any other possibilities that may work in order to maximize the capacitor? Just to make sure, you say that by adding more insulator layer is not going to increase the capacitance but will only related to let the capacitor hold more voltage, right?
Thanks
Thanks
We are not seeing a lot of effort on your part on this schoolwork project, beyond asking for others to do your work for you on the Internet. You need to figure out what experiments to do in your limited lab time to help you optimize your design. What experiments are you going to do?
We don't spoonfeed students here at the PF. Show that you are doing a lot of work, and we can provide some tutorial hints. Otherwise, your thread will be closed. Learn how to learn.
EDIT -- google Capacitor Construction. Have you at least tried that yet?
I did some research on it. And the experiment what I am able to think about is to prepare several capacitance with different types of dieletric. Once I know which dielectric works the best, then I will move forward to work on minimizing the width between conducting plates, maximizing the surface area, and work on paralleling or stacking few capacitance at once. At the same time, I should reduce the air volume between the the layer.
Very good.
Very good.
I will update it back once I finished the experiment. Thanks for the help.
I just meant that trying to spool up three strips of material - draped over a table or a chair - can easily introduce kinks and bends. If you start off with three, pre-prepared spools of tape (foil, foil and clingfilm), held firmly and under control, you have a better chance of laying them up neatly on the final article (just like a real capacitor making machine does, in fact). Neatness is everything if you want to maximise the capacity.
1. How can I create a DIY capacitor at home?
To create a DIY capacitor at home, you will need some basic supplies from your local supermarket. These include aluminum foil, plastic wrap, and a dielectric material such as paper or wax paper. You will also need a pair of scissors, some tape, and a power source.
2. What is a capacitor and how does it work?
A capacitor is an electronic component that stores electrical energy. It consists of two conductive plates separated by a non-conductive material, known as a dielectric. When a voltage is applied to the capacitor, one plate becomes positively charged and the other becomes negatively charged, creating an electric field between them. This stored energy can then be released when needed.
3. What are some common uses for capacitors?
Capacitors have a wide range of applications in various electronic devices. They are commonly used in power supplies, audio equipment, and electronic circuits to store energy, filter out unwanted signals, and regulate voltage. They are also used in cameras, flashlights, and other devices that require a quick burst of energy.
4. How do I construct a DIY capacitor using supermarket supplies?
To construct a DIY capacitor, follow these steps: first, cut two squares of aluminum foil and two squares of plastic wrap, all of the same size. Place one square of foil on a flat surface and cover it with a layer of plastic wrap. Repeat this process with the other square of foil and plastic wrap. Next, place the two foil-plastic wrap layers on top of each other, making sure the foil layers are facing each other. Then, add a layer of dielectric material (such as paper) between the two foil layers. Finally, tape the edges of the layers together and connect the foil layers to a power source.
5. Are DIY capacitors safe to use?
DIY capacitors can be safe to use if constructed properly and used with caution. However, it is important to note that they may not be as reliable or durable as commercially produced capacitors. It is recommended to use caution when handling homemade capacitors and to avoid using them for high-voltage applications.
  • DIY Projects
  • DIY Projects
  • DIY Projects
  • Electromagnetism
  • DIY Projects
  • Electrical Engineering
