Simple dynamics problem, I can't seem to get the answer to
  • Thread starter Thread starter rock.freak667
    Dynamics
A car with an initial velocity of 5 m/s accelerates at 0.06t m/s² while traveling around a circular track with a radius of 300 m. The total distance for one-third of the track is 200π m, leading to the equation 200π = 5t + 0.01t³ for determining time t. Users confirm that there is a real solution for t, which can be approximated using online calculators, but solving the cubic equation by hand is complex and time-consuming. The discussion highlights the challenges of finding roots of cubic equations without advanced calculators, emphasizing the difficulties of manual methods like the Newton-Raphson approach. Understanding these dynamics and solving for velocity and acceleration at the specified distance is crucial for completing the problem.
rock.freak667
A car travels around a circular track having a radius of 300m such that when it is at point A, it has a velocity f 5m/s, which is increasing at the rate of \dot{v}=0.06t m/s^2. Determine the magnitudes of the velocity and acceleration when it has traveled one-third the way around the track
n,t-coordinate system
a=\sqrt{a_t^2+a_n^2}
a_n= \frac{v^2}{r}
Since the radius r=300m, the total distance the car will travel is 2 \pi r= 600\pi m
So I want to find v and a when the distance = 200pi
Now at A, \dot{v}=a_t=0.06t
Initially at A,t=0 and v=5
so
\int^{v} _{5} = \int^{t} _{0} 0.06t dt
v=5+0.03t^2
Thus
\int ^{s} _{0}= \int ^{t} _{0} (5+0.03t^2) dt
s=5t+0.01t^3
When s=200\pi
200\pi=5t+0.01t^3
Which I do not know how to solve since there is no rational root.
Was I going on the correct track?
rock.freak667 said:
200\pi=5t+0.01t^3
There is a real solution. (Yes, you're on the right track.)
Well I had to use an online calculator to get t=35.579993691668676.
But my normal calculator doesn't have a function for cubic equations. How would I normally solve it without a computer? I know the rational root theorem but if I were to use the Newton-raphson method, I'd spend a lot of time finding a starting point and doing the iteration.
Solving a general cubic equation by hand is a bear. There's an analytic solution, but I wouldn't dare attempt it from memory. (I too have been spoiled by fancy calculators.) Here's one version: http://mathworld.wolfram.com/CubicFormula.html"
