Simple harmonic motion and particle speed
The discussion revolves around simple harmonic motion (SHM) and the relationships between acceleration, velocity, and amplitude of a particle in motion. The original poster attempts to determine the amplitude and maximum velocity given specific parameters, including maximum acceleration and frequency.
  • Participants discuss the relationships between maximum acceleration, frequency, and amplitude, questioning how to derive the amplitude from given equations. There are attempts to clarify the conversion of frequency to angular frequency and the implications of trigonometric functions in the context of SHM equations.
Participants are actively engaging with the problem, sharing equations and clarifying concepts. Some guidance has been provided regarding the maximum values of sine and cosine functions, and there is an ongoing exploration of how to derive the acceleration equation from the velocity equation.
There is a noted uncertainty regarding the derivation of certain equations and the interpretation of variables, such as time and angular frequency. Participants express a lack of confidence in their mathematical skills, which may affect their understanding of the concepts discussed.
ahhgidaa
Motion of particle shows a max acc. of 30 m/s2 and a frequency of 120 cycles per minuet. assuming SHM determine, the amplitude and max velocity.
i found the sqrt of k/m to be 12.57 even though neither was given and the frequency to 2 cycles/sec.
i do not know what relations to use to work out the the rst.
Vmax = Xmax sqrt k/m , but where do i get X max
and where do i find Vo
thank you.just trying to figure it out for studying. apparently i suck at it.
Consider that v = dx/dt and a = dv/dt for a point bouncing up and down on the string.
To get ω, just convert the given frequency to radians/sec. (Which you already did.)
That equation is not quite right. (Look it up again.)
Start with a corresponding equation for the maximum acceleration, which will allow you to solve for the amplitude.
v=dx/dt= -wAsin(wt) and x= Acos(wt)
what is the little t, time. is the time the period? and is 2 cycles per second 2 rad/sec. ?
and just fmi, with the differential equation with x(t) when would i use that. when i have as specific time. I am just unsure about a lot of stuff. sry.
ahhgidaa said:
v=dx/dt= -wAsin(wt)
and x= Acos(wt)
Good. Now you're getting somewhere. Continue to get an equation for the acceleration.
t is just the time, not the period.
No. To convert from cycles to radians, realize that 1 cycle = 2pi radians.
and just fmi, with the differential equation with x(t) when would i use that. when i have as I am just unsure about a lot of stuff.
Those expressions give you the position and velocity (and, when you get the third equation, acceleration) as a function of time. How would you modify them to get the maximum values of those quantities?
well i found the equations on the next page of my book. ha. and have been looking at them and i do not see how they mathematically went from -wAsin(wt) to just wA for Vmax. I am looking at the graphs to but my math isn't strong enough to see how they could drop the trig func. but the A i got was .189m and and Vmax of 2.35 m/s. and I am glad that I am not afraid to ask questions here because i never do in class which is my bad. but why isn't it s^2.
What's the maximum value of sine or cosine?
Close enough.
What do you mean? Why isn't what s^2?
for velocity graph the max amplitude is Vmax at 3/4T and for the displacement x at 0 was 3/4T.
how do you get that acc equation? i thinks that's what you were trying to have me do. but what do i think or do to go from V = -wAsin(wt) to Vmax = wA.
dx/dt at x=0? then diff that. which i dnt think i can do.
Again I ask: What's the maximum value that a sine or cosine function can have?
To get the acceleration equation, use a = dv/dt. Take the derivative of the expression you have for V.
Note that the only variable is in the sin(wt) part. That's why I'm asking you to tell me what's the maximum value for sin(wt).
ahhgidaa said:
1, -1
Right!
So to get the maximum value in those SHM expressions we can replace cos(ωt) and sin(ωt) by 1. (We just care about the magnitude, so sign isn't important.)
So if y = A cos(ωt), then ymax = A. (And so on.)
  • · Replies 51 ·
  • · Replies 17 ·
