Simple Harmonic Motion: Mass on a spring
A massless spring with a spring constant of 27.7 N/m is analyzed with a 0.31 kg mass attached, which descends when released from an unstretched position. The discussion clarifies that while kx = mg represents the static equilibrium, the dynamic situation requires considering the maximum displacement, leading to the equation 2mg = kx. This accounts for the mass falling past the equilibrium position before rebounding, highlighting the oscillatory nature of simple harmonic motion (SHM). The forces acting on the mass during its descent and ascent are analyzed to understand the relationship between acceleration and displacement. Ultimately, the maximum displacement of the mass is determined by applying the principles of SHM and the forces involved.
delecticious
A massless spring with spring constant 27.7 N/m hangs vertically. A body of mass 0.31 kg is attached to its free end and then released. Assume that the spring was unstretched before the body was released. How far below the initial position does the body descend?
F = kx
I realized that the weight is the force so I set kx = mg, however I was told that in actuality the equation should be 2mg = kx, so my question is why is it 2mg? I don't get it.
kx = mg would be the situation in a static case, i.e. not initial movement.
In problem given, the mass is allowed to fall with the spring unstretched, so the mass will fall past is equilibrium position, reach a point where it stops, then rebound. If not damping is present, the mass would oscillate according to SHM.
Now in equilibrium, kx = mg, so that deflection would represent the equilibrium position. Starting from the unstretched position, the mass falls a distance x to the equilibrium position and then must continue another displacement x until it stops (velocity equals zero) at which point the spring pulls back.
http://hyperphysics.phy-astr.gsu.edu/hbase/permot2.html#c3
hi astronuc, i still don't understand why it's 2mg
do you mean that F = -kx only applies before the spring moves?
because I've measured spring constants by plotting Force vs. elongation graphs
where force = mass hanging from spring *9.8
is that correct
Its probably because they're not asking for its descent to equilibrium. As Astronuc said, what will happen when attaching the weight is that the spring will first move towards some maximum displacement, then move backwards towards its equilibrium position. What they're probably asking for is the maximum displacement.
I think what Astro said is the easiest way to get to the answer. He finds the delta x to go from initial position to equilibrium. Then applies the symmetry of harmonic motion to get the final answer.
Alternately, here is one way to get the 2mg=kx that you are asking about. In the initial position (unstretched string, mass hanging on it), what is the sum of the forces? Use F=ma to find a and call it a1. Now the mass falls to the equilibrium (a=0) point and continues down to the bottom of the motion. At that point, what is the sum of the forces? Use F=m*a2. Again apply the symmetry of the problem. What is the relation between a1 and a2? Plug in a1 for a2 and what do you get?
Basically what 2mg=kx (=Spring Force) is saying is that the spring is pulling the mass back up at a force equal to twice it's weight.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
