Simple Harmonic Motion MCQ Question
therisingpower
A simple pendulum was moving in front of a horizontal scale. the extreme positions of the bob were at the 300mm and 500mm marks. The bob moved from the 350mm to the 450mm marks in 1.0s. What is the period of the oscillations?
A. 2.0s
B. 3.0s
C. 4.0s
D. 6.0s
x = x0 sin(wt + fai) , where "fai" is the phase difference.
fai/2pi = x/wavelength, x is the distance apart between 2 points out of phase.
T=2pi/w , where T is the period and w is the angular velocity.
i tried solving by using x0=100,
taking 400 to be the equlibrium point, since it was middle of 300 and 500.
thus, amplitude is x0=100.
so by the formula x = x0 sin(wt + fai),
i still need to find fai and x.
so i used fai/2pi = x/wavelength.
and then I'm stuck.. ):
any help would be appreciated. thank you!
Your starting equation is OK, but the phase is an irrelevant complication here. If you clock starts when the pendulum is at the equilibrium position, the equation is simply
x(t) = A sin(ωt) with A = 100 m.
Note that 350 mm is -A/2 and 450 mm is +A/2. This should help.
To solve this, I first used the units to work out that a= m* a/m, i.e. t=z/λ. This would allow you to determine the time duration within an interval section by section and then add this to the previous ones to obtain the age of the respective layer. However, this would require a constant thickness per year for each interval. However, since this is most likely not the case, my next consideration was that the age must be the integral of a 1/λ(z) function, which I cannot model.
