Simple harmonic motion problem involving matrices
The discussion revolves around deriving the equations of motion for a system of two equal masses connected by springs. The initial equations presented for mass one are deemed correct, while the equations for mass two are identified as incorrect due to the omission of the third spring's influence. Participants emphasize the need for a free body diagram to clarify the forces acting on each mass. It is noted that each mass interacts with two springs, necessitating adjustments to the equations to account for all forces. The conversation concludes with a recommendation to revise the equations and the diagram for accuracy.
ABoul
2 equal masses are joined together by a spring of stiffness k. each of the masses is then connected to a wall with an identical spring. derive the equations of motion in matrix form. (a diagam has 2 masses with x1 on top of the first mass and x2 on top of the second.)
hooke's law: F = kx
mass 1:
mx1'' = F(x2 - x1) - Fx1
mx2'' = Fx2 - F(x2 - x1)
^ are these correct?
Mass one looks good but mass two is off. What happened to your third spring ?
Also, draw yourself a free body diagram.
i did. there are only 2 displacements (x1 and x2), right? the extension of the third spring is not kx2?
There are only two equations, but you need to include the third spring. If the masses are going to move springs 1,2, and 3 have to move with them.
but each mass is connected to 2 springs. therefore each equation should only have 2 terms. the only mistake i can see with the second equation is that Fx2 (force from the THIRD spring) should be negative. oh, and sorry if i haven't been clear enough -- the diagram goes like this:
[wall] [spring] [mass 1] [spring] [mass 2] [spring] [wall]
Mass one depends upon springs 1 and 2. Mass two depends on springs 2 and 3. Rewrite your equations and redraw your FOB.
