Simple Harmonic Motion Question
A particle undergoing simple harmonic motion with an amplitude of 10 cm and a frequency of 5 Hz was analyzed for its position, velocity, and acceleration at t = 3.5 ms. The initial approach used the cosine function, which was incorrect since the particle starts at the equilibrium position (x=0) at t=0. The correct equations involve a sine function for position, leading to x = 0.1*sin(10πt), with corresponding velocity and acceleration equations derived from it. After correcting the phase difference, the revised equations were confirmed to be accurate. The discussion emphasizes the importance of correctly identifying the initial conditions in harmonic motion problems.
coffeem
A particle undergoes simple harmonic with amplitude of 10cm and frequency 5Hz. If it passes through the equilibrium position (x=0) at time t = 0, calculate the position, velocity and acceleration of the particle at t = 3.5m5 ms.
Given that:
A = 0.1m
f = 5Hz
therefroe w = 2pif = 10pi
phase difference = 0.
So using the standard: x = Acos(wt+PD)
where PD = phase difference.
I get x = 0.1m.
differentiating this I get:
v = -0.34 m/s
and again differentiating I get:
a = -98.0 m/s^2.
However these answers appear to be wrong. Any advice on where I am messing up?
coffeem said:
Given that:
A = 0.1m
f = 5Hz
I get x = 0.1m.
v = -0.34 m/s
a = -98.0 m/s^2.
Your attempt at getting 'A' and 'ω' are correct. But the particle starts at x=0, t=0. So your general equation should be sine and not cosine.
If it said x=A at t=0, then you'd use cosine.
Thanks - that makes sense. I just read the position from the book without thinking...
So:
x = 0.1*sin(10pi*t)
v = 0.1*10pi*cos(10pi*t)
a = -0.1*100*pi^2*sin(10pi*t)
would that be correct? thanks
So:
x = 0.1*sin(10pi*t)
Yes that should be correct now.
Thank you very much - i appreciate the hepl.
