Simple Harmonic Motion + Regular Kinematics
The discussion centers on a particle's motion along the x-axis, initially at 0.250 m with a velocity of 0.200 m/s and an acceleration of -0.290 m/s² for 5.80 seconds, resulting in a position of -3.4678 m and a velocity of -1.482 m/s. The next phase involves the particle transitioning to simple harmonic motion (SHM) for another 5.80 seconds, with the equilibrium position set at x = 0. The user attempted to apply SHM formulas, using amplitude and angular velocity, but struggled to incorporate the effects of the previous constant acceleration. Clarification on how to combine these concepts in calculations is requested, adhering to forum rules that require an initial attempt at problem-solving.
fnaarfnaar
A particle moves along the x axis. It is initially at the position 0.250 m,
moving with velocity 0.200 m/s and
acceleration -0.290 m/s2.
Suppose it moves with constant acceleration for 5.80 s.
Position of Particle after 5.80 Seconds - -3.4678 m.
Velocity of Particle After 5.80 Seconds -1.482 m/s
Next, assume it moves with simple harmonic motion for 5.80 s and x = 0 is its equilibrium position.
What is its position at the end of this time interval?
What is its velocity at the end of this time interval?
Attempts :
I attempted to use the formula X(t)= A cos (wt), with A being the amplitude 0.250 (because a spring can't stretch farther than its intial position) and w = angular velocity which I used 0.2 / .25.
For the velocity I used the formula- v(t)=w A sin (t)
From this point I was completely lost because I could not find a way to incorporate the constant acceleration. Simple Harmonic Motion equations
if you could leave an explanation, it's be greatly appreciated!
You need to make an attempt at solving the problem yourself and showing us what you did before you can receive assistant, per the forum rules.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
