Simple Harmonic Motion with Spring
A massless spring hangs vertically and stretches from 0.22 m to 0.75 m when a 0.68 kg mass is added, indicating an equilibrium position. At time t=0, the mass is given a downward velocity of 4.88 m/s. To find the acceleration at t=0.46 s, the spring constant must first be calculated using the formula k=(mg)/(yeq-y0). The only forces acting on the mass are the tension from the spring and its weight. Correctly determining the spring constant is essential for solving the acceleration problem.
getty102
A massless spring is hanging vertically. With no load on the spring, it has a length of 0.22 m. When a mass of 0.68 kg is hung on it, the equilibrium length is 0.75 m. At t=0, the mass (which is at the equilibrium point) is given a velocity of 4.88 m/s downward.
At t=046s, what is the acceleration of the mass? (Positive for upward acceleration, negative for downward)
\SigmaFy=-k(yeq-y0)
\SigmaFy=may
The only two forces acting on the mass are the Tension from the spring and weight. So
Tsm-(mg)=may
I am now stuck wondering if that was a good place to start. Is the traditional way to solve this problem to find the spring constant first?
Yes you should find the spring constant first as you will need it later on to get the acceleration at t= 0.46.
I have k=(mg)/(yeq-y0). I don't think this is right.
Right, well you are given m, y0 and yeq and you know g. So you can get k.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
