Simple Harmonic Oscillation Problem
The discussion revolves around solving for the first time after t=0.00 s when the velocity of an object in simple harmonic motion, given by v(t)= -(4.04m/s)sin(21.0t + 1.00π), equals -0.149m/s. The original attempt to solve the equation led to a negative value for t, indicating a potential error in the approach. Suggestions include adjusting the phase constant from π to -π and using a graphing calculator for visualization. The importance of understanding the periodic nature of the sine function is emphasized, particularly in relation to the phase shift. Clarifying these points can lead to a correct solution for the problem.
GarrettB
The velocity of an object in simple harmonic motion is given by v(t)= -(4.04m/s)sin(21.0t + 1.00π), where t is in seconds. What is the first time after t=0.00 s at which the velocity is -0.149m/s?
N/A
I thought this was an easy question but there must be a flaw somewhere in my logic. I've tried -0.149=-4.04*sin(21t+pi). However, solving for t gives me a negative number. I've also tried doing using cos instead of sin to get rid of the phase constant, but still the wrong answer. It's given me aprrox. 0.07s. Any help would be appreciated
A couple of suggestions.
If you change the argument of sin by 2Pi what happens.
You might also use a graphing calculator to plot the function to get some insight as to what is going on.
Nothing happens if you change it by 2Pi? Since that's one full cycle. But this is 1pi?
You probably found the sin^-1 of .149/4.04 and that gave you a negative t. Could you change the 1pi to -p1 and resolve?
Of course you can, because its a cycle. Appreciate the insight.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
