Simple Inequality with Modulus Question
kuskus94
Determine m :
|x-10|<{1}/{m}
if its final form is :
|x^{2}+{4}x-140|<1
To remove the modulus, square them...
I have tried to assume that if
|x-10|{m}<{1}
then, I can find
|x-10|{m}=|x^{2}+{4}x-140|
|x-10|{m}=|(x+14)(x-10)|
but, can I omit (x-10)?
kuskus94 said:
|x-10|{m}<{1}
You can't do that because m might be negative for some x. Try the squaring hint.
|x-10|{m}=|(x+4)(x-10)|
There's an error in that step.
Okay, sorry it should be
So, if I do this :
(x-10)^2{m}^2=((x+14)(x-10))^2
is it possible?
kuskus94 said:
it should be
Not quite. Should be |x-10||m|=|(x+14)(x-10)|
But if you go back to |x−10|<1/m you can observe that m is necessarily non-negative, which simplifies the logic.
So what form should m take to make that guaranteed, and ensure m non-negative?
because |m|=\frac{|(x+14)(x-10)|}{|(x-10)|}, is it |m|=|(x+14)| ?
Almost. If m were negative, would it satisfy the requirements?
Hmmm... so, I need to add m&gt;0 to the equation or something like that.
m=|x+14|; m&gt;0?
m=|x+14|; m&gt;0?
Yes, except that you don't now need to specify m >= 0. It follows from m=|x+14|.
So, the final answer is m=|x+14|?
I am still in doubt. :confused:
Looks right to me. Did you try plugging it into the original inequality?
