What Method Should Be Used to Integrate 2x/(2x+1) dx?
  • Thread starter Thread starter mohabitar
    Integral
mohabitar
A little rusty on this stuff.
Integral of: 2x/2x+1 dx
What method would I use here?
2x/2x+1 = 1+1 =2. Integral of 2 is 2x+c.
Or you meant 2x/(2x+1)? If so, you have to use parentheses.
Than use the substitution 2x+1=y.
ehild
Sorry yes this is what I meant: 2x/(2x+1)
However, if I use u=2x+1, du is 2dx, and this is not present on the top. 2x is. If I solve for dx, I get du/2. This still doesn't help out much. Can you clarify some more please..
u=2x+1, du =2dx, dx=du/2.
\int\frac{2x}{2x+1}dx =\frac{1}{2} \int\frac{u-1}{u}dx
Can you proceed from here? ehild
Sorry this still doesn't help narrow it down. There are still variables in the numerator and denom, so I can't just solve this right away. This looks familiar though. I think I have to break this up into two integrals, but I don't have the slightest memory of how to do that.
Divide the numerator by the denominator.ehild
Ah ok looks like I'll have to go reteach myself long division :/
Is this the only way this can be solved? How about splitting it into 2 integrals, or was I wrong about that?
No, you split it into two integrals after you did that division. It is simple, just think, how to simplify (2x+6)/2, for example?
ehild
If you have difficulty with long division (and you really shouldn't by the time you are taking Calculus), then divide after the substitution:
\int\frac{2x}{2x+1}dx= \frac{1}{2}\int\frac{u- 1}{u}du=\frac{1}{2}\int \frac{u}{u}+ \frac{1}{u} du= \frac{1}{2}\int(1- \frac{1}{u})du= \frac{1}{2}\int(1- u^{-1})
