Negative Angular Velocity: Is It a Change in Direction?
  • Thread starter Thread starter NotaPhysicsMan
    Urgent
Negative angular velocity indicates movement in the opposite direction rather than a complete stop before changing direction. The calculations provided show that transitioning from a positive to a negative angular velocity does not imply a halt in motion but rather a shift in rotational direction. Angular acceleration measures the rate of change of angular velocity but does not directly indicate a change in direction. The confusion may arise from the different scales used for measuring angles, but this does not affect the sign of angular velocity. Understanding these concepts clarifies the relationship between angular velocity, direction, and acceleration.
NotaPhysicsMan
Ok,
If my angular velocity is negative, does that mean I've stopped and now changing directions in terms of my movement?
Thanks.
Angular velocity is rate of change of angle about a fixed point, so if it's negative it means you're now moving around the point in the opposite direction.
Ok, so let's say my calculation came to:
120 degrees=+2.02 rad/s
150 degrees=-0.60 rad/s
Does this mean that in between this point, I stopped my movement in the positive and now am traveling in the opposing direction? So angular acceleartion doesn't really tell me if it has changed direction. Just tells me if it's slowing down or increasing.
150 degrees should give more radians than 120 degrees. It's just measured on a different scale so that shouldn't cause it to become negative.
Try using google if the conversion isn't working out too well.
