Simple question about current draw
  • Thread starter Thread starter kickflipper11
    Current
The discussion centers on the application of Ohm's Law in understanding current draw in electrical circuits, particularly when comparing resistors and motors. A circuit powered by 10V with a 1 Ohm resistor will draw 10A, but when using a motor, the resistance changes, affecting current flow. Larger motors require more current to operate, which can lead to confusion regarding their resistance compared to smaller motors. It's clarified that a higher power motor at the same voltage will have lower resistance, while a lower power motor will have higher resistance. Understanding these relationships helps in grasping how power supplies must be capable of providing the necessary current for different loads.
kickflipper11
Hello,
I've been working with some electrical stuff at my internship lately, but I don't have any real background in it, so I've been trying to learn what I can from the internet. One thing that I don't get involves Ohms law:
If I have a circuit powered by 10V with just a 1 Ohm resistor, the current flow will be 10A (I think). If that resistor is replaced by a motor, which would have a much larger resistance, the current flow will drop according to I=V/R. But common sense tells me that a larger motor would need more current for it to run. I'm sure I'm confusing the concepts. Basically, I can't mesh the idea that current draw will be higher to power larger motors and the idea that I=V/R.
I hope that makes sense, any response would really be appreciated, thanks!
I guess I'm not really clear what your issue is. Ohms law is it.
If you maintain a 10v supply (capable of supplying whatever current is needed) and you have a 1 ohm resister load then you get 1 amp of current and if you increase the resistance then you get less current and if you decrease the resistance you get more current.
A 10V DC motor generating 100Watts would need 10 amps (and so by implication would have a 1/10 ohm resistance.
It is possible to have a DC power supply that generates 1am with no problem but just can't hack 10amps, so with a given input voltage, stronger motors require a power supply that can drive more load.
In a theoretical diagram this is the case.
In a real world application a voltage source will have a current supply limit. If you find a lab power supply, most of them have the ability to be current limited, so if you set the limit to 1A and then tried to put 10V across a 1R resister, the supply would hit 1A and the voltage will drop back according to Ohms Law to 1V.
Thanks a lot, that actually did answer my poorly phrased question. I had it in my head that a larger motor that had a higher rated power must have a higher resistance than a lower power motor, which was why I was confused because that wouldn't make sense with Ohm's Law. I didn't realize that a lower power motor would have a higher resistance. So a:
10 V, 100 W motor needs 10A and has 1 Ohm of resistance
while at 10 V, a 10 W motor needs 1 A and is 10 Ohms?
you got it
Ok, I'm glad you cleared that up, thanks a lot it was really buggin me.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
