Simple question electron speed
  • Thread starter Thread starter pulsemaster
    Electron Speed
When bending an electron beam near the speed of light, the relationship between magnetic field strength and the electron's speed or energy is crucial. In high-energy applications like the IBA Rhototron and ILC Tesla klystron, electrons are accelerated significantly, requiring precise magnetic field adjustments for effective beam bending. The discussion raises the question of whether the magnetic field strength must increase proportionally with the electron's speed or energy to maintain the same trajectory. It also suggests that, at extreme speeds, the magnetic field strength might approach a constant value. Understanding this relationship is essential for optimizing electron beam manipulation in advanced accelerator technologies.
pulsemaster
hi i am new here and i have a simple question.
if i am using a magnet to bend an electron beam. as the electron speed increases near to the speed of light.
does the magnetic field strength vary directly with the speed or energy of the electron to hit the same target.
thanks
You did not say if the electron beam was in a vacuum or partial vacuum, as in an electron tube where it can only travel a shameless one tenth the speed light.
let us asume near the speed of light
let us assume near the speed of light electrons and we need to bend the beam 90 degrees.
a good exaple of beam bending is the IBA Rhototron as each pass thru the field in the vacuum is a 1MeV and is bent to re enter the vacuum when it exits the vessel. this bending occurs 5 times to achieve 10 MeV. ( 2 MeV per pass thru)
another exaple is the ILC tesla klystron cavities. these cavities speed the electrons up to 40 MeV / meter depending on the RF field strenght and current flow. I like this one because the cavities are super cooled with liquid nitrogen so the electrons have no energy until they are boiled off the cathode with a laser pulse.
any how if the electron is approaching the speed of light in these chambers does the magnetic field strength vary with speed or energy of the electron? maybe even approach a constant?
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
Thread 'How can I find the cleanout for my building drain?'
I am a long distance truck driver, but I recently completed a plumbing program with Stratford Career Institute. In the chapter of my textbook Repairing DWV Systems, the author says that if there is a clog in the building drain, one can clear out the clog by using a snake augur or maybe some other type of tool into the cleanout for the building drain. The author said that the cleanout for the building drain is usually near the stack. I live in a duplex townhouse. Just out of curiosity, I...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
