What Determines the Direction of Centripetal Force and Acceleration?
Centripetal force and acceleration always act towards the center of the circular path. To maintain an object in circular motion, a force must be applied inward, counteracting the object's inertia that would otherwise cause it to move outward. The equations for centripetal force (mv^2/r) and centripetal acceleration (v^2/r) reinforce that both quantities are directed towards the center of the circle. This inward direction is essential for keeping the object in a stable circular trajectory. Understanding this concept is crucial for solving problems related to circular motion.
shizzledizzle
How do I find the direction of the centripetal force and acceleration?
mv^2/r - centripetal force
v^2/r - centripetal acceleration
Would it be inward or outward the radius?
Think of this: If you wanted to keep a ball rolling in a circular path, which way would you push it (once it has started moving)? Towards the center or away from it?
So that would be the same for both acceleration and force?
Yes, because F=ma, where F and a are vectors and m is a (positive) scalar.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
