Time Dilation in Relativity: Solving a Simple Observer Problem
  • Thread starter Thread starter unscientific
    Relativity
The discussion focuses on a problem involving time dilation in relativity, where an observer measures the time taken for a laser pulse to travel to a stationary mirror and back. The calculations for the time taken for each leg of the trip are presented, using the Lorentz factor (γ) to account for the moving observer's perspective. The time for the pulse to reach the mirror and return is derived, confirming that the application of time dilation is correct. The participant expresses satisfaction with the solution process, noting that it was straightforward for an exam question. Overall, the calculations align with the principles of special relativity regarding time measurement for different observers.
unscientific
An observer fires a laser pulse at a stationary mirror located at distance d away and measures the time taken. A second observer moves in the same direction as the beam with velocity v and sees these events.
According to each observer, how much time will it take for the pulse to make each leg of the trip and back and what is the total time taken from emission to detection?
Event 1: Laser pulse is fired
t1 = 0, x1 = 0
t1' = γ(t1 - vx1/c2) = 0
Event 2: Laser pulse bounces off mirror
t2 = d/c
t2'
= γ(t2 - vx2/c2)
= γ(d/c - vd/c2)
= (γd/c)(1 - v/c)
Event 3: Laser reaches back observer
t3 = 2d/c, x3 = 0
t3' = γ(t3 - vx3/c2)
= γ(2d/c)
= (2d)/√(c2 - v2)
Is there anything wrong with my working?? I can get to the first to the last step by simply applying the time dilation effect by using Δt' = γΔt...
Everything looks good. And yes, the first to last step can also be obtained using the time dilation formula. Good.
Thanks! That was pretty easy for a 10 mark exam question o.O
