Simplify Equation: Get Help Now!
  • Thread starter Thread starter javii
    Simplify
9 replies · 2K views
javii
The way i have simplified it:
I do not know it is the way to do it.
But if so, now I need to give the answer in cartesian form, and I think I need to use the formula:
meaning it will look like:
Anyone who can tell me if I am on the right track?
Thank you
What you have is not an equation... An equation always has an = sign between two expressions.
Thank you
You're on the right track, based on a quick scan, but you're not done. Cartesian form means a + bi (or a + jb, as you are writing things.)
One thing, though -- the first image (which by the way we discourage) has what appears to be the magnitude of the numerator. Because you posted an image, I can't copy just the numerator to show you what I mean.
One other thing -- the work in the inages is very neat, but not well organized. You start off with an expression that you're supposed to simplify, but you have other things in there that are elaborations of parts of what you're working on, and there are indications that what you're starting with and what you're ending with are actually equal. The = symbol is used for that purpose.
What is j ? ##j = \sqrt{-1}## ?
Second step is wrong.
##|(1- 2j)(1/\sqrt{2}) + (1- 2j)j(1/\sqrt{2})|/...##.
First of all, thank you for your feedback.
I know that I am not done, as you say I need to find the answer in Cartesian form in Denmark (a+jb), that is why I am asking if i have to use the formula:
which I am confirmed that I have to.
And I can see, what you mean with the equal sign. Thank you.
Rather than rely on a formula (that by the way is incorrect), the way that division of complex numbers is to multiply by 1 in a suitable form.
If ##z_1 = x_1 + jy_1## and ##z_2 = x_2 + jy_2##, then
##\frac{z_1}{z_2} = \frac{x_1 + jy_1}{x_2 + jy_2} = \frac{x_1 + jy_1}{x_2 + jy_2} \cdot \frac{x_2 - jy_2}{x_2 - jy_2}##
##= \frac{x_1x_2 + y_1y_2}{x_2^2 + y_2^2 } + j\frac{x_2y_1 - x_1y_2}{x_2^2 + y_2^2}##
In the next to last step, I am multiplying by 1, in the form of ##x_2 - jy_2## over itself. The reason for multiplying by ##x_2 - jy_2## over itself is that this is the complex conjugate of what was originally the denominator, ##x_2 + jy_2##.
The result is now in Cartesian form, with the first fraction being the real part, and the stuff after j being the imaginary part. In your formula, you omitted j.
Will it then be:
x1=
y_1 =
x_2 =
y_2 =
so:
in cartesian I get
= 1.7134 +j1.7134
I really hope this is correct.
Thank you
As far as I can see you are on the wrong track. Your expression is of the form ##N/D##, where the numerator is ##N = |(1-j2) e^{j \pi/4}| ## and the denominator is
$$D = \sinh (j \pi/6) + 3 (\cos(\pi/6) + j \sin(\pi/6)).$$
I assume that ##j2## in the numerator means ##2j##, not ##j^2##.
When evaluating ##N## you first expanded ##e^{i \pi/4}##, then multiplied by ##(1-2j)##, but you did it all wrong (at least as written and read using standard rules). You should have
$$(1-2j) ((\sqrt{2}/2 + j \sqrt{2}/2) = (1-2j) \sqrt{2}/2 + (1-2j) j \sqrt{2}/2\\ = 3 \sqrt{2}/2- j \sqrt{2}/2 \doteq 2.121 - 0.707 j ,$$
but you have written
$$(1-2j) \sqrt{2}/2 + j \sqrt{2}/2 = \sqrt{2}/2 - j \sqrt{2}/2 \doteq 0.707 - 0.707 j.$$
You are bound to get the wrong answer!
However, all that is a real waste of time; just pay attention to post #5, and use the much simpler result ##N = |1-2j| |e^{j \pi/4}|.## Can you take it from there?
